Getting rid of column-lock (completely)
I've completely removed the column-lock motor assembly from my C5 racecar, and plan on installing the kit that comes with the recall campaign. Since this is a dedicated track car, I want zero probablility of column lock while "driving" the car.
So - the question is: Will the PCM disable fuel when I try to start it up and/or will there be additional messages on the DIC?
Thanks,
-Bruce
This is exactly what the (aftermarket) CLB or (GM) "harness K" does.
Once you disable the motor electrically, and use either of these feedback devices to satisfy the BCM, the mechanical stuff becomes dead weight.
The dealer can't do it but the car's owner can.
Thanks,
-Bruce
I would make a couple of comments. First to satisfy your BCM, you have 3 choices:
1. Install a CLB module which you can purchase from Corvettes of Houston for $49.95 http://www.corvettesofhouston.com/
2. Build your own for less than $25 which you can see my plans at the following link: http://shelor.net/Z/CorvetteForum/Cscokd/
3. Install the (GM) "harness K"
All three of these solutions do the same thing in that they fool the BCM.
From what I know so far, the "GM harness K" actually leaves the column lock motor connected to the BCM yet it adds a CLB relay to fake out the BCM. I assume the only way this would work is for the steering lock plate to be removed. But why would GM leave the lock motor in the circuit? This is a mystery to me. I would be interested to know more about the column lock motor, lock pin and lock plate that you said you removed. Many of us have had a little nagging question in the back of our minds about how the motor and lock pin actually works. It was my belief that the lock motor moves the lock pin via a worm drive gear so it would be basically impossible for the lock pin to jiggle around and accidentally re-engage the lock plate in the steering column even though the CLB has been installed and the lock motor disabled. From your experience after removing yours, can you or any others reading this post shed any light on this subject for us? We would appreciate any info you might be able to provide. Thanks!
John
I know that it can be installed but he said "the kit that comes with the recall campaign". The only kit that comes with the recall is for automatics.
From a pure electrical theory standpoint, electrical contacts do tarnish over time if unused. When passing electrical current, the slight arc that occurs during the closing of the contacts, does tend to renew and clean the connection.
The logical argument to that argument, is that if no problems occur from not transferring any current during this closure of contacts (disconnection of motor)...why would problems occur if those contacts (ithat no longer transfer current) go bad over time, and how would they even be detected if they went undetected before?
Confused? A more simple scenario, but the same situation....
You have a light bulb in your house you never want on anymore.
Your solution is to remove the light bulb, but continue to flip the switch each day...the room never lights up due to the missing bulb.
GM is saying doing that could cause the light switch to go bad.....but how do you know the switch is bad if it doesn't do anything to begin with?
BTW, if you use a single-coil relay like I did, you can skip the diodes.
He said he was going to install it.
The "only" kit that comes with the recall for A4s and the "only" kit you can purchase to install in a MN6 are one in the same.
Yes they are one in the same but he stated the kit came with the recall when in fact it did not for manual trans C5's.
Thanks,
-Bruce
The motor drives a pin and the pin physically opens/closes a small micro-switch. When the pin is retracted (un-locked), the switch is closed (completes a circuit). When the pin is extended, the switch is open. The motor and pin are an integral assembly.
I don't have the service manual in front of me, but I recall something (PCM or BCM) sensing the voltage on that circuit (typical sensing circuit with 12v followed by a resistor - if the circuit is closed, the module "sees" 12v; if the circuit is open, it "sees" a reduced voltage determined by the internal resistor in the module).
With this setup, there is a delay between the unlock/lock command, and the output of the feedback circuit that determines the state of the lock mechanism. Is the module smart enough to look for this delay? Is the module "looking" for the state transition? In other words, when I lock the column, does the BCM/PCM look for the voltage on the sensing circuit to go from "high" to "low"? Or, does the PCM/BCM simply care that the sensing circuit shows "low" when the column is locked (e.g. it doesn't look for the voltage transition)?
Thanks,
-Bruce
Again, I understand all this. I was just correcting what another member stated as being false.
