1ST time dyno
Old Feb 7, 2005 | 10:17 PM
Jerryk's Avatar
Jerryk
Default 1ST time dyno
Well its about time i did this, heres what i got 385.8 Engine HP with 335.5 to the wheels and 345.1 Torque. A/F was way to lean at 14 so i made this ajustment today and now show be at 13.3 and also increased the timing by 1 degrees so ill give it a few days to let the computer adjust, i did put back the stock MAF sensor housing as well. So over all im a happy camper
Old Feb 7, 2005 | 11:15 PM
Dave68's Avatar
Dave68
NOT BAD AT ALL! Congrats!
Old Feb 7, 2005 | 11:48 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
not bad at all mine is listed in my sig
Old Feb 7, 2005 | 11:50 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Can you post the graph chart? Thanks
Old Feb 8, 2005 | 12:00 AM
bayarea's Avatar
bayarea
nice numbers
Old Feb 8, 2005 | 08:02 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Good results!!
VR
Old Feb 8, 2005 | 10:59 AM
Half-Life's Avatar
Half-Life
i'd thought the standard conversion from rwhp to crank hp was 15% drivetrain loss for a MN6. if you're getting 335.5hp at the wheels, shouldn't it equate to around 394hp at the crank?
please correct me if i'm wrong, i've never done a dyno test before and all i know is what i've read so far on the forum. i will be heading to VetteDoctors in 2 wks for a LS1 Edit & testing so any clarification/tips would be very helpful.
thanks.
Old Feb 8, 2005 | 11:26 AM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
Please don't tell us these #'s are for a basically "bone stock" C5. If it is, here we go again.
Old Feb 8, 2005 | 12:42 PM
Icemanskis's Avatar
Icemanskis
St. Jude Donor '05
His mods are listed in his signature.
Corsas, x-pipe, JBL headers, blackwing, 178 therm
Old Feb 8, 2005 | 01:38 PM
Jerryk's Avatar
Jerryk
I have hard copys ill see about taking a snap shot and post them, had it done at speed merchant of san jose on a dynapck series v4.l5.2
Old Feb 8, 2005 | 03:10 PM
ArKay99's Avatar
ArKay99
Very nice numbers. Just curious, what was your stock timing?
Old Feb 8, 2005 | 03:16 PM
Dave68's Avatar
Dave68
thanks.
That depends. Was the correction factor SAE or STD? Assuming it is SAE, then I would say that the MN6 is contributing a 12-14% loss, not 15, based upon my observations. This would mean that you have between 381 - 390 HP at the crank.
Old Feb 8, 2005 | 03:56 PM
vetterdstr's Avatar
vetterdstr
I have been on a dyna-pac before, they read a little lower than the dyno jet...
VR
Old Feb 8, 2005 | 06:11 PM
Mikelly's Avatar
Mikelly
These are basically the same numbers I pulled with an LS6 intake/ Shaner Tbody/ LGM Headers/ SLP 3inch Cats/ and a full 3 inch exhaust back to Borla Stingers... my torque was up to 353 at the max...
What amazes me is when I tell non-C5 owners what my car turned, they go "Is that all?"
I really need my heads/ cam motor done!
Mike
Old Feb 8, 2005 | 09:02 PM
Jerryk's Avatar
Jerryk
Sorry dont know what the stock timing was, however i have the predator tune which i changed the timing to +1 degree and get 3 on the KR at WOT so i will be taking it down to 0 and see how that works out, zero being predator tune which is advance, but how much i dont know. next i think rockers this i can do myself as well
Old Feb 8, 2005 | 10:01 PM
Dark-Knight's Avatar
Dark-Knight
See sig, similar mods with similar dyno results. 21st Cent MC did the work on mine too.
To 1ST time dyno
