Any Tips on Balancing Wheels?
I know I want to use stick on weights, but is there a ‘best’ place to locate them on my wheels? Does anyone have pics?
In general, you have 3 options for balancing alloy wheels
1- Coated clip-on weights on both sides
2- Coated clip-on weights on the inner side alone (called static balance)
3- stick-on weights on one or both sides.
The 1st is the most accurate for best balance at high speed. That is why they come from the factory that way.
The 2nd is cosmetically best as there are no weights visible. The balance is good, but you might get some vibration at speeds above 65 mph. It's a hit-or-miss situation. On high quality wheels and tires like the Corvette, this is less risky. If you do extreme speed driving (over 100mph) do not static balance.
The 3rd....I would not recommend on the thin spoke Corvette wheels due to cosmetic reasons. The stick-on weights on the inside rim area will be easily seen. They are huge too. A 1 ounce strip of stick-ons are 2" long because a 1/4 ouce weight is 1/2" square.
Tips on preparing used wheels & tires for balancing.
- Clean the rims and tires completely. It's best to take them off the car to get the best cleaning results. A dirty wheel and/or tire will be out-of-balance. You don't want the tires balanced with weight that changes with cleanliness.
I have worked on cars with grease blobs from a grease job formed on the inside of a rim, and then gravel stuck to the grease. Talk about an unexpected wheel weight.
- remove all stones stuck in the tire threads. The weight of the stone influences the balance too.
- be sure the tire pressure is proper.
- Do not spin balance a wet tire if it can be avoided. If so, spin it once to get the water off. Then balance it.
High quality rims and tires generally balance better than cheap ones. Wheel weights are minimal on our Corvettes because of that. If after a balance on your Corvette, you see one of your wheels with lots of weights added, there is likely a problem. A whobble in the rim, dirt on rim or tire, stones in tire threads. It could also be that the wheel was not properly mounted on the balancer.
Keeping your rims and tires clean, keeps them in balance longer.
I have stick on weights (came with the wheels) , but mine are flat. I don't think there are as ugly/harmful because at least they're not clamped on the edge of the rim. $.02 cents deposited.Dave Q.
the the weights on the outer rim look. I will notice a little shake at
around 80mph. Of course doing a 140mph burst, you wouldn't notice
it as much, unless you were maintaining that speed for more just that
burst.
I'm shipping my car overseas for the 06' Le Mans, Nurburgring, and the
autobahn where I'll be sustaining speeds well over 100mph. I will get
the wheels balanced with the weights on both sides for that.
I had made an appointment with Discount Tire. Manager came out to help on it. They didn't run it up on their normal lifts, let me use my jacking pucks, they were REALLY careful with the pressure sensors, and commented that I shouldn't use the crimp-on weights! They used the small stick-on squares on the inside of the rim! They balanced out great! You can still see the weights if you look, but they really don't detract from the look. Most of the weight was needed to counter-balance the sensor. Anyway, sticky weights work just fine!!!
PS - The only rotten thing is that it was raining this morning, so now she needs a little clean-up.
Great info there Ron.
Let me ask you, if a wheel set was balanced with stick ons that had high speed vibrations, and you changed to a static balance, would that have any negative affect on the low-speed balance?
Meaning, if the balance was more geared toward a vibration-free high speed ride, would the lower speeds show any increased vibrations?
Thanks.
The guy at Discount Tire said he would include RoadForce balancing at no extra charge. Anyone know what that is?
Then balance the assembly, since corvette rims are all machined they require almost perfect tires.
I had 1 bad Goodyear and they replaced it under warrenty, but then thats another story.
And I prefer the stick on weights but they do get real close on the fronts, in fact since I have the factory mags they are the only ones I can use. And I have also found 1 place that knows about the low profile weights for the fronts, and it sure wasn't the dealer!
