Redline vs Amsoil test
Old Feb 8, 2005 | 03:28 PM
mountainmotor's Avatar
mountainmotor
Default Redline vs Amsoil test
We have seen a bunch of Amsoil testing and comparing other oils . I've never seen them test against Redline though .
Here's a rare Redline initiated test
http://kozmik.guelph.on.ca/gtdprojec...soil_S2000.pdf
What say ye ?
Old Feb 8, 2005 | 04:04 PM
Laguna Blu's Avatar
Laguna Blu
Way to go Redline though I must admit to having Amsoil Series 2000 gear oil in the diff.
Old Feb 8, 2005 | 11:41 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
What say ye ?
Mountainmotor,
Any idea what that test isn't on Redline's corporate website?
Any idea why it is on this guy's website?
Although I don't doubt the authenticity of that document, nor do I question that Redline makes a good oil, but I seriously question why it isn't on Redline's website, but this one is instead:
http://www.redlineoil.com/whitePaper/motoroils.pdf
Is it possible that they were challenged on this report and had to pull it?
I'm wondering about the validity of the test method of testing virgin oil, then putting it in a motor where its zinc and phosphorus are used up as they bond with the engine (the Ford in this case) then retesting it. How much of the AMSOILs anti-wear additives are still in the Ford motor protecting it? Does this test show us that if you essentially take out the anti-wear additives (they are left behind in the engine the oil was drained from) that the Redline's performs better than AMSOIL? But how fair a test is that? When you pour a bottle of AMSOIL in your motor, the anti-wear additives are in it.
Thoughts?
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Feb 9, 2005 | 11:48 AM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Well I haven't had much experience with amsoil. But I have seen what redline's setup doesn't do to bearings. We started pulling apart a race motor with over 14 weekends on it. They have always used redline and the motor looked perfect. The bearings were just great, the pistions only had a few marks on them. The motor was just clean as could be. This is not the first motor that we have been in after many of hard track miles, with great results using redline. We have used redline for years with never any troubles due to oil break down or anything related to the oil. I even put redline in my lawn mower, racing kart but not my daily driver(it burns too much oil 230,000 miles).
Randy
Old Feb 9, 2005 | 12:32 PM
Automag928's Avatar
Automag928
I think we will have some good, legitimate testing results completed soon comparing oils that are constantly being brought up in threads like this....
Old Feb 9, 2005 | 12:43 PM
mackvest's Avatar
mackvest
Default super oil
http://www.neosyntheticoil.com/
Old Feb 9, 2005 | 01:47 PM
IMQUIK's Avatar
IMQUIK
Amsoil is still the first & best!
Old Feb 9, 2005 | 03:21 PM
Laguna Blu's Avatar
Laguna Blu
Just keep changing the oil frequently and don't worry about it.
Old Feb 9, 2005 | 07:30 PM
RoHo's Avatar
RoHo
If your going to do a test how about throwing in a little Royal Purple, I see more and more guy's using this in their trans and rear ends and swearing by it.
Old Feb 9, 2005 | 08:34 PM
C5Jim's Avatar
C5Jim
For me Redline is the best. I use Redline MTL in the MN6 and Redline 75W90 in the rearend.
Why? Because I've used that combo in my '88 IROC-Z for the last 12 years and after 362,000 miles everything is fine. The posi rear still works!! (both wheels hook up)
I use Mobil 1 in the engine. The Redline motor oil is too expensive.
To Redline vs Amsoil test
