Help!!!!!!
Old Feb 9, 2005 | 02:34 PM
canadianguy's Avatar
canadianguy
Default Help!!!!!!
I was about to lower car, and loosened the wrong bolt on the other side of the shock, now I can not tighten it, does anyone know how, I just spent over an our trying to figure it out with just basic tools.
Old Feb 9, 2005 | 02:37 PM
woosch's Avatar
woosch
You are going to need the correct allen key to hold the bolt while you tighten the nut.
I'm not sure what the correct torque spec is for those.
Old Feb 9, 2005 | 02:39 PM
canadianguy
The socket will not go around bolt with allan key, do I need a special tool?
Old Feb 9, 2005 | 02:43 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Use a box wrench
Old Feb 9, 2005 | 02:45 PM
canadianguy
Originally Posted by CHRIS NJ C5
Use a box wrench
I have no idea what that is, can you explain please. Sorry I am dumb.
Old Feb 9, 2005 | 02:50 PM
canadianguy
ok, I googled it, got to go to store, thanks!
Old Feb 9, 2005 | 03:18 PM
Rizzo1's Avatar
Rizzo1
Yikes.... You're working on lowering your Vette and you don't know what a box wrench is? Might want to take this job to a shop. Also I see a Vise grip in the picture. Perhaps this is not the right tool for this procedure. While you are at the tool store you might want to pick up a good socket set and a set of wrenches.
Old Feb 9, 2005 | 03:53 PM
ALLEGRO's Avatar
ALLEGRO
Old Feb 9, 2005 | 04:05 PM
canadianguy
Your probably right, but I want to learn. I just got back with a bigger wrench, and fixed the problem, I just didn't have a big enough wrench. Now I can not get the lowering bolts to move. Tryed wd40 and dish soap, still no luck. What can I do, I'm going crazy!
Old Feb 9, 2005 | 04:15 PM
DickieC.99's Avatar
DickieC.99
From the Tech Tips section....
"With the car jacked up & ready to lower (as in previous tips), place another small/standard jack under the end of the spring & jack it up enough to relieve some of the tension on the spring. This will allow the bolts to turn VERY easily with an open end wrench (or sometimes by hand). A small wood "block" between the jack & spring will protect the spring from possible damage."
Old Feb 9, 2005 | 04:20 PM
MSGvette's Avatar
MSGvette
Maybe this will help https://www.corvetteforum.com/techti...D=27&TopicID=1
Old Feb 9, 2005 | 04:36 PM
Fast one's Avatar
Fast one
That's the lower ball joint nut. If you apply some force under the lower a-arm such as a scissors jack or jack stand then the tapered ball joint should be tight enough for the nut to be turned without the ball joint turning. You now need a torque wrench to properly torque the nut.
Old Feb 9, 2005 | 05:00 PM
canadianguy
Do you know what the proper tourque is? Thanks
P.S. I did it! The front is lowered as far as it goes stock, although I just put it down and now it seems a little higher Hopefully it just needs to settle. Hope the rear is easier, man I'm dumb!
To Help!!!!!!
