Radiator/condenser shroud
Old Feb 9, 2005 | 05:30 PM
Hall1836's Avatar
Hall1836
Default Radiator/condenser shroud
Is the piece between the condenser and the airbox supposed to be a solid piece or is there an opening about 15 inches square?
Old Feb 9, 2005 | 06:00 PM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
stock original shroud was solid...sounds like yours has been modified.
Old Feb 9, 2005 | 06:04 PM
Hall1836's Avatar
Hall1836
Thanks for the response. Do you know if this is normally cut when putting in an after market cold air box. I'm removing a Vette Doctors cold airbox and K&N filter going back to ZO6 box. Guess I could fabricate a piece of aluminum across opening. Thanks again
Old Feb 9, 2005 | 06:10 PM
12stepvette
yea...pretty normal modification...diverts more cold air to the intake. Shouldnt have any problem putting a sheet of aluminum over it...
To Radiator/condenser shroud
