Tranny Fluid
Old Feb 9, 2005 | 05:43 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Tranny Fluid
It has been suggested to me to use Redline MTL in the M6 tranny. I've always used sythetic ATF in my other cars. Any comments on what is the best to use?
Old Feb 9, 2005 | 11:21 PM
silverz06vette's Avatar
silverz06vette
I would only use ATF. JMO
Old Feb 10, 2005 | 08:40 AM
dmtnt's Avatar
dmtnt
St. Jude Donor '03-'05-'06 & '12
Use Redline D4 ATF
Old Feb 10, 2005 | 08:52 AM
MHVette's Avatar
MHVette
Originally Posted by dmtnt
Use Redline D4 ATF
That's what I run...
Old Feb 14, 2005 | 06:12 PM
Last C5's Avatar
Last C5
Use Redline D4 ATF
MTL is OK if you're racing.
Old Feb 14, 2005 | 08:19 PM
Cajundude's Avatar
Cajundude
Thanks for the replies! I went ahead and got the Redline D4 ATF for my breakin and some for after the break in.
Old Feb 14, 2005 | 09:24 PM
C5Jim's Avatar
C5Jim
I tried Redline D4, but I didn't see that much improvement.
I called Redline and asked if I could use MTL (like I do in my T5 in my IROC). Redline told me I could, but I might experience hard shifting during extremely cold days.
I swapped the D4 for the MTL and the shifting is much improved. I had the car out when it hit 6 degrees and it was a bit hard to shift, but not much. After a couple of miles it shifted smooth again.
BTW, D4 and MTL share the same viscosity......70W.
Just my $.02
To Tranny Fluid
