Steering rack help(pls)
Old Feb 10, 2005 | 02:15 PM
Bill.Jarboe's Avatar
Bill.Jarboe
Default Steering rack help(pls)
I pulled the rack in order to replace the balancer(it seperated) and when it all went back together the car is throwing a C1283... The whole balancer job only took a couple hours and went well but now the car insists that the active handling has issues... I fear that a wire may not be plugged in someplace or that the column may have been turned 360 degrees while the rack was out... it all looks , feels and drives great outside this error, any suggestions?
Old Feb 12, 2005 | 10:40 PM
Bill.Jarboe
Default steering rack help
Never mind, it turned out to be 360 out... old world engineering did the trick. After looking closely at a steering wheel position sensor at the dealer I saw the simple answer... 4 complete turns left(past logical ending point), back to top(steering wheel in straight ahead position), and then 2 turns right and it is centered... every... time . I love it when the obvious works.
