Dyno's differ; Dynojets, for example, read higher than Mustang dynos. Could be any one of a number of things that lead to erroneous #'s. Running it down a 1/4 mile will tell for sure if you are 'really' missing HP.
My '99 C5 w/ 26K miles dyno'd at ONLY 270HP. The car has a K&N cold air in take and Borla exhaust too.
What could be the problem, or more important, is there a solution to get back that 80-90HP?????
But I would like to add that on a DynoJet dyno with those mods if you are running an M6 I would expect to see ~310 to 315rwhp and if an A4 ~295 to 300rwhp. If you dynoed on a Mustang dyno those numbers are probably correct.
On my 00 Frc w/35k miles stock i got 295RWHP and 300 ft.lbs.tq. That was on a mustang dyno. Since then I have added Slp Loudmouth catback exhaust, few more mods then back to the dyno.
This was my first dyno run. It is an automatic too. Honestly, I don't know that much about the mechanics of cars, and I don't know what kind of dyno machine it was (I can find out though). The reason for my concern, is that other vettes have been run on this dyno (same/similar mods) and showed higher HP (340+).
Plus, the tech guy, who has a vette, felt the reading was accurate and that there was an obvious lack of HP output.
Sounds like a Mustang dyno. As stated above, the mods you have will most likely show zero gains. Sounds like the dyno op. may be trying to sell you some parts.
Definately need to take it to the track, 1/8 or 1/4 to find out.
1/8 should put you around 8.7-8.9 sec. and 1/4 should put you around 13.5 sec. give or take a few tenths.
The dyno's read horse power at the wheels not at the crank, big loss for an Automatic about 18% loss of power , so that 270 RWHP could be accurate.
Also, consider, when's the last time you had an oil changed or trani fluid changed, or other fluids that could possibly effect performance to a slight degree. Just a thought.
I'm about to have my stock 02 automatic dyno'd in a couple weeks, I'm not expecting much more then 285RWHP to be honest, I know I'll be disappointed, but I'll just go out and smoke a Cobra or something to make me feel better... ha
I know many people (F-bodies especially) that have dynoed just over 300 rwhp and still ran 11 second ET's.
There are many different varibles as to why your car dynoed low, perhaps you have some compression issue, leakdown issues, or even tranny issues. Any A4 car wil dyno lower than an M6 and perhaps your tranny was slipping and you didnt even know it.
But as far as your actual numbers, they are not that below par. If I were you, I would do a compression check at least, and go from there.
Take that thing to the track! It might surprise you.
Thanks all for your help... The reason for my concern, is that I don't want to be blown away by another car and the reason is my car is not performing at the correct HP levels...I want the "bite" that goes with the bark ...anyways, I am going to show these replies to my tech guy and see what he says and keep all of you posted!
Try some new plugs and wires. If you have the stock platinums in there and you've lost the pucks the performance will suffer. I'd recommend the KGN TR55, TR55IX(I found worked nicely to smooth out the idle). The wires get old and the resistance is higher to begin with than many after-market wires like MSD. A loss of 30hp at this level is minimal and probably has more to due with a tune-up than engine issues. If you had something more serious wrong the power loss would be more dramatic. Also, as a side note you will get better hp numbers with a 2.73 rear than with taller gears so crawl under the back end and see what gears you have, it'll say on one of the tags on the rear housing.
It was tested on a Dyno Dynamics Dynamometer. Does this help you guys with the reading I got (270 HP)?
My concern is that the tech guy felt my numbers were low based on his running of other similar vettes. (I have to ask him what the readings are based on)
Also, what's your advice for next Mods that give noticable results?...(headers/cams)?
Thanks!
PS 90 droptop: I don't want to give out the guy or place as I am confident he is not selling me a bill of goods, he's a good guy with a good rep in the area. Thanks.
