Fuel Pump
Old Feb 11, 2005 | 10:27 AM
Special K's Avatar
Special K
Default Fuel Pump or Out of Gas
Hi Guys & Gals,
I thought I ran out of gas. The engine quit on me and my wife went to town and got 4 gallons of gas that we put in the car. It wouldn't start. I used the GM procedure for starting after running out of gas.
Had the car towed in to Chevrolet garage. The fuel pump was bad. 15,000 mi on the car. If I ran out of gas, could that have caused the fuel pump failure?
Thanks,
Bob
Old Feb 11, 2005 | 02:40 PM
Special K's Avatar
Special K
Ttt
Old Feb 11, 2005 | 02:46 PM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
Originally Posted by Korreck
Hi Guys & Gals,
Thanks,
Bob
YES electric fuel pumps can experience failure if you run them out of gas
Old Feb 11, 2005 | 06:53 PM
Special K's Avatar
Special K
Thanks Rob. The dealer didn't know. I would still like to know what happens to the pump to cause complete failure.
Old Feb 11, 2005 | 11:12 PM
Special K's Avatar
Special K
It's beginning to look like this is something no one else has experienced.
Old Feb 12, 2005 | 12:13 AM
lost's Avatar
lost
Ive never had an electric fuel pump go out on me, they usually will get noisy, now I have had the fuse blow or the relay go out. Ask for the bad part, never mind it's in warranty, let the dealer screw GM.
Old Feb 12, 2005 | 10:47 AM
white top's Avatar
white top
fuel pump uses fuel for cooling no fuel no cooling not good for the pump.
Old Feb 12, 2005 | 11:06 AM
Special K's Avatar
Special K
I was thinking those same thoughts but I wouldn't think it could have gotten that hot. I know nothing about these pumps but it's hard to believe they would be that sensitive. I wish they mounted it outside of the tank.
Old Apr 19, 2005 | 08:23 PM
vettenuts's Avatar
vettenuts
I knew that was true on the C4 I had, guess it still continues on in the C5 then. Probably even more of a concern because of the funky passing of fuel between tanks too. Guess I will keep mine at or above 1/4 tank.
Old Apr 26, 2005 | 07:53 PM
isosceles's Avatar
isosceles
That's because when the guage gets to "E" we STOP FOR GAS!!!
BTW, that's about every 5 miles in my car.
Old Apr 26, 2005 | 08:36 PM
Special K's Avatar
Special K
I'm impressed. You had to dig deep to get this one. Check this out. I'm still laughing.
http://forums.corvetteforum.com/show...1&forum_id=103
Old Apr 26, 2005 | 09:43 PM
Freestyler's Avatar
Freestyler
i had an issue the other week, felt like a ditz tho, i pulled in with a rough low idle, parked on my return a day later it wouldnt start .... ?? wtf, i know it was near empty but the 'reserve fuel' had 'only just come on' ... the tell tale NOISY pump wasnt anywhere to be heard... calls to GM ardmore )losers( quoted 500 for a pump and that there was a left side pump and a right side pump (*******) - called Gene our Buddy at FredBeans - there is ONLY ONE pump (with a sender unit for the other side) - 290.00 all in.
got 4 gallons into the baby and small miracle, it must have covered the float / level / whatever as it started up and i could, THANKFULLY hear the NOISY pump again!
ps - what did they charge for the replacement pump? labor?
Freestyler
Old Apr 26, 2005 | 09:48 PM
Special K's Avatar
Special K
Freestyler
Don't know. It was under warranty.
Bob
To Fuel Pump
