Headlights would not come on, so I opened them manually, turned lights on - no result, checked circuit breaker looks good, light switch when activated turns on dash lights - any suggestions
just for clarification, the lights do not come on and the doors do not open, and it is both sides? When you say you checked the circuit breaker, what specifically did you check?
How do you know the circuit breaker is good?? I have the book open and am ready to give you assistance. I need you to check the following:
Do the park , Day time running and tail lamps work.
If you pull the high beam switch on does the high beam indicator on the dash light? If the day time running lights and the high beam indicator lights, breaker# 52 is GOOD!
Check instrument panel electrical center fuse # 22 Breaker # 52 (swap one of the other 20 amp breakers in that position and see if things change.
Q: Do the park , Day time running and tail lamps work
A: YES
Q: If you pull the high beam switch on does the high beam indicator on the dash light?
A: NO
Thanks for your replys!
Reason: Forgot to Thank
