Axle seals
Old Feb 13, 2005 | 07:55 PM
KRK's Avatar
KRK
Default Axle seal removal?
How is everyone pulling the axle seals out of the differential?
Old Feb 22, 2005 | 04:13 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Did you do this yet? I was told a small scewdriver is the way to go. Since the new seal is rubber coated do not put any type of sealer on it when you put it in the diff.
Old Feb 22, 2005 | 05:13 PM
KRK's Avatar
KRK
Yes, I've already completed the install of the Yank 3500, TransGo and 3.42 diff. I used a small screwdriver on the TC seal, but was questioning my method... found a seal puller for $10 at the local parts store that is basically a specialty prybar, which worked quite well.
Thanks for the reply.
Kalin
To Axle seals
