- C6 Corvette Total Recalls and Technical Service Bulletins
Important information to help you understand your Corvette..
Browse all: Exterior How-Tos
Steering Column Lock FAQs - please read before you post (sticky please)
The fact that it is a GM recall, will the dealer take care of this free even if it may be a second time?
I doubt you understand what the recall was for. It was NOT because the column locks, it was supposed to, but rather it was because under certain conditions it is possible to drive the car with the column locked. Clearly a safety issue and why NHTSA got involved. If your colugmn is locked and you experienced the 2mph fuel shutoff, then your car HAS been serviced and the recall on that VIN is CLOSED. The bill could be anywhere from a few hundred to well over $1000 if the dealer can convince you that the lock motor has failed and must be replaced.
I suggest that you put some time into reading the last 10 or so pages (not posts but PAGES) of this thread to learn more about the problem and what your options are that can fix the car for well under $100 and it will be a permanent fix, unlike what the dealer will do.
If you take the time to fill in your profile and provide some info about the car, (like year, trans type, any modifications, etc) you might get some specific help. Without that info there are way too many variables that depend upon year, trans type, etc.
I would suggest from experience the lmc5 module. Richard will help you out as he has will several hundreds maybe even thousands of people that have had or are having these issues.
I followed instructions and removed the Harness K. My car runs just fine now. I just took it for a spin around the block. Thanks to you and all on the forum for the help. A couple of questions, what risk do I now have with the steering column bynot having the Harness K in place any longer? Is there anything else that may come up by not having it or any aftermarket bypass in place? Thanks very much.
I think my relay in the passenger footwell is toast...Keep getting the pull key / service column lock messages...What would be the best way to test this ?
I have an A4 with the recall done, and have had the shut off adjusted to 200....Will the CLB or LMC5 work for me? I'm just tired of getting the messages.
Let me know your thoughts and thanks,
Mark
However, if the car site for a few days I appear to have no electric current. If I remove the negative from the battery and connect it back the electricity is back and the car will start.
And, not sure if it's related but now I get Service ABS, Service Traction Control System, and Service Active Handling System.
Any ideas
1) Lock motor has failed. Possible but not especially likely.
2) The GM K Harness that would have been installed as part of the recall service has fried. Possible and very likely.
3) The Column Lock Relay in the passenger footwell may have fried. Possible but less likely than the GM K Harness frying.
You could purchase and install an LMC5 and the message should go away. However remember that the BCM on some cars do not like the LMC5 and you may end up going back to the supplier to get the LMC5-R.
You could also use the procedure in post #1772 above and eliminate the GM K harness. If that is what has failed then the message will go away and you would not have to spend any additional $$$$.
Wow, my head is spinning after all the information I just waded through. So, here's my story. I have a '97 C5, which I've owned since 97/98(can't remember), bought from dealer(It was sales Mngr's car). Yesterday, I get in my car after hoopin it up at the gym for hours. I put the key in the ignition, start her up and shift into D. Just about the time I shift into D and start slowly idling forward, out of my parking spot, I turn the wheel a hair to the right to straighten out and hear a "click" in the wheel. It locks up on me, I am in drive and rolling forward!!!!. I immediately hit the brakes and reverse back into my parking space. The DIC has the "Service Column Lock", etc. etc. I have only had this happen to me once before, many many years ago, and I got out of it by just fiddling with the key in ignition a bunch of times. I went on my iphone and got on here to read up on the CL and proceeded to try the hard crank of the wheel onto the stops left & right. I did this many times and it did not seem to be working. Needless to say, I was frustrated and pissed to have to deal with a safety issue like this(Thank God I wasn't driving on the street/freeway, etc. and it happened!). So, now I find myself in the ship with many other Vette owners, having had this happen to them, in trying to figure out the best course of action. I assume I should call the dealer and have a chat with them about if the recall has been done on my car, etc. I would just like to do a perm resolution(remove the CL mechanism, etc), so it will NEVER be a possibility to happen while driving.....I have an 8-YO daughter and use the vette to shuttle her to/from school and this really freaked me out this time(Last time it happened I was parked, NOT moving!). I'd appreciate advice on what to do here!
I suggest that you do a search on CLB or LMC5 (plenty of hits will come back) and after some research, order and install either a CLB or LMC5 and forget the dealer service. I doubt the dealer will tell you the truth about the lock motor because he can charge you somewhere between $500 and $1200 or more to replace the lock motor rather than just doing the recall service free. Sound like I don't trust stealers????????
My car is a '97 and I have never had the recal service done, thus so yes, the column locks when key is out. I too DO NOT trust stealers and posted on here because I really want to avoid taking it to them if I can. I am fairly handy with the Vette and have done many things on my own, so I wanted to get some thoughts from others on what to do here. I do not want to go through that situation ever again that I experienced at the gym the other day! So, what your saying is that when they put in the smaller lock plate, they also repro the PCM to shut fuel off at 2mph when it senses the CL has NOT retracted, even though it might have? Is my PCM currently prog'd to do this now? I did not hit 2 mph when just idling forward, off the brake, rolling out of my parking space, so I didn't experience the cutoff if it was present. It is a VERY SCARY notion that my car could potentially do this while flying down the freeway or somewhere like that? This huge thread
mentions, IIRC that some bypass kits mess with the voltage to the BCM? and thus could potentially burn it out in the future from trying to "get around" the CL prob???? Anyway, thanks for any advice and I'm lookin forward to removing this dayum prob once and for all in the best way I can.
Steve
The dealer recall service replaces the lock plate with one that cannot intercept the lock pin thus the column will never lock again. This is standard stuff for the 97 - 200 automatics. The recall service also sets the 2mph fuel shutoff in the PCM. The small lock plate came standard from the factory on 2001 and newer automatics.
If your car has in fact never had the column lock recall service done to it the fuel shutoff is NOT set so either a CLB or LMC5 should cure your problem once and for all. Both devices require that the column be unlocked before they are installed. The major difference is that the CLB is installed under the drivers side knee bolster into the connector that the lock motor would normally connect to ( with the column unlocked, you disconnect the lock motor male connector and plug the CLB male connector into the female connector that the lock motor was plugged into. This does leave factory wiring in place between the connector under the drivers side knee bolster and the BCM)
The LMC5 has you disconnect wires directly at the BCM that would otherwise go to the lock motor and connect their device directly to the BCM. Because it connects directly to the BCM there is no factory wiring for the column lock system left in the circuit. Factory wiring could be an issue if you have had rodents get into the car and they chewed the wires for the column lock system components. Usually that's the cars in the part of the country that get stored for the winter.
I also suggest that you have your battery checked out. The MOST COMMON cause of the column lock system symptoms is a weak or bad battery or loose or corroded battery connections. I suggest that this is what triggered the symptoms in your car.....
The column lock system electronics need greater than 12.5 "NO LOAD" volts to function properly. that's because the column lock system runs long before the engine is started. If your battery is close to that voltage the charge is low. You cannot use the dash guages to measure no load volts. With the engine running you read the output voltage of the alternator. With the key on and engine off you have many electrical circuits in the car loading the battery. Measure no load volts with the neg battery cable disconnected and the DMM connected directly across the battery posts.
If money is the issue you could build your own CLB. Here is a link:
http://shelor.net/Z/CorvetteForum/Cscokd/
I think the parts cost is around $15. You reuse the male connector from the lock motor I believe.
So, I checked my Optima Red Top voltage......No good....Not holding charge. Ordered and installed a Delco 78-7Y(which is now a 78PG) and the CL is locking/unlocking STRONG. When I had the Optima in there, it sounded very weak when it would engage/disengage. The Delco has a 110RC and my Optima Red Top is marked with a 90RC. Another thread in CF had a link to a vid about this issue and the lecturer said that a Chevy recommends a 120RC, which the 78-7Y used to have. I spoke to the parts dude at Chevy about all this and he was pretty knowledgeable about the CL issue and everything(maybe he has a Vette too). Anyway, he said the issue creeps up with pretty much ANY batt when it starts to weaken and not hold its charge(the elctrical gremlins come out then, it seems).....Which is pretty much what I've experienced with this prob. So, now I'm good with no phantom locking issues, but will order one of the bypass kits to further end this PITA prob for me. Thanks to 8VETTE7 for all the help and advice
Since posting (at 12:29) with the new batt installed, I had the CL freeze up again(once more) after about 3 hours of the Vette sitting in my garage. Got it to unlock after pulling key out, getting Q-tip soaked in rubbing alcohol and cleaning inside of ignition switch and key pellet. Q-tip came out with black residue on it and I cleaned it good with both ends of Qtip. I have NOT experienced a CL prob since and that was Tues afternoon. I've been in/out of the car approx 20+ times since that incident with no probs or close calls....Each engage/disengage has been strong. I've ordered the LMC5 from Richard(had nice chat with him too) and will install it when it gets here to rid this scourge hopefully once and for all
Steve
I'm now in deep trouble because I was hit w/dui since this happened in a parking lot at my fav rest.Yes I was showing off.
I need someone to step up to the plate and agree it could happen.
It did.I loved my car but unless someone helps all my ins.money will go to an attorney.John
