Air Cleaner Modification
Old Feb 14, 2005 | 09:15 PM
Pamm Seifert's Avatar
Pamm Seifert
1st Gear
Default Air Cleaner Modification
undefinedundefinedundefinedI have a 2003 convertible and I want to get more air into the air cleaner. Does anyone know where to drill holes to get the air in easier? What size holes? Do I drill them in the top of the air cleaner cover or the bottom?
Old Feb 14, 2005 | 09:49 PM
S76HeliPilot's Avatar
S76HeliPilot
Buy a Z06 air box cover. It has a bigger opening and will look a lot nicer than a cut up box. You can probably get a used one from someone who put in an aftermarket air system.
Old Feb 14, 2005 | 09:52 PM
Derek Zalewski's Avatar
Derek Zalewski
I would not drill holes in the bottom side of the airbox. (That is the dirty side).
I would recommend a Z06 airbox lid...
or for even more reduction in restriction the zip-tie modification. (No airbox lid - you just risk the potential for water intrusion). If you worry about hydorlocking the motor then I would go with the Z06 airbox lid.
Good luck
Old Feb 15, 2005 | 12:45 AM
VETFVER's Avatar
VETFVER
Hi Pamm:
If you will send me your email address, I will send you pictures of my Z06 Air Filter Cover modification. It is very easy to do and will put more and colder air into your engine.
Dan
Old Feb 15, 2005 | 04:02 AM
Scott04Z's Avatar
Scott04Z
From: I'm not quite middle aged and I only own one gold chain! San Jose CA
You may also want to consider putting an aftermarket intake on the car. The Halltech is a good one because it also comes with a larger air bridge, but the Donaldson Blackwing is just basically a large air filter that mounts on the end of the maf. Better flow than the stock setup and easy to replace. Plus you get a little extra hp for your trouble!
Old Feb 15, 2005 | 08:33 AM
IMQUIK's Avatar
IMQUIK
Click my link & have a look at some I have done.
Old Feb 21, 2005 | 09:37 AM
paxton50's Avatar
paxton50
I am also interested in modifying my stock airbox lid. Someone has to have done this before or has some info on a good way to modify it.
Old Feb 21, 2005 | 03:48 PM
DRGIZMO's Avatar
DRGIZMO
Cruising
I recommend going to the aftermarket air intake. Corvette Fever has done some articles on this so check their site. Just FYI.
Old Feb 21, 2005 | 04:03 PM
Mike Mercury's Avatar
Mike Mercury
I'd suggest the Z06 air lid if yoru car is still under warranty and you have a picky dealer.
Other than that, the Blackwing and others are the way to go
Old Feb 21, 2005 | 04:43 PM
Elpelon's Avatar
Elpelon
Did this on my 02 vert. The Z06 box I ordered from GM parts direct was inexpensive and the opening is probably 10x the size of the stock C5 cover. Takes 10 minutes to install.
Old Feb 21, 2005 | 07:38 PM
VETT2DY4's Avatar
VETT2DY4
Do you have a prt number for the Z06 Air Cleaner cover? I can't seem to find it on GMPartsDirect. Thanks
Old Feb 21, 2005 | 07:43 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have a complete 2001 Z06 air box that I will sell you for $30. I was going to install it on my 98 coupe but sold it before I could install it. I have no use for it.
Let me know if you would like to purchase it.
Bill Curlee
Old Feb 21, 2005 | 09:32 PM
Shall's Avatar
Shall
St. Jude Donor '05-'06-'07-'08-'09-10-'11-'12-'13-'14-'15-‘16-‘17
IIRC, the 02 style Z06 lid is 12567571
Old Feb 21, 2005 | 10:22 PM
stockC5's Avatar
stockC5
I did the zo6 air box on my 2002 vert and added a k&n filter. About a week later I cut out another 25% from the air box with a dremel tool. Big difference from stock.
Old Feb 22, 2005 | 01:50 PM
VETT2DY4's Avatar
VETT2DY4
Thank you
To Air Cleaner Modification
