foglights
Old Feb 15, 2005 | 09:38 AM
Twospeed's Avatar
Twospeed
Default foglights
I have a question?
I've seen pictures of C5s with the headlights down and the fog lights on. I have a 2002 C5. If I turn the headlight switch to the second position the headlights come up but don't go on. What do I have to do to get the fog lights on with the headlights down? Anybody else run into this situation. The main reason for this is I like the way the cars look in the pictures running this way.
Twospeed
Old Feb 15, 2005 | 10:05 AM
rudolph schenker's Avatar
rudolph schenker
Turn your park (running) lights on only (1st position), then turn on your fogs. The main headlights will stay down.
Old Feb 15, 2005 | 10:10 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Old Feb 15, 2005 | 11:29 AM
ALLEGRO's Avatar
ALLEGRO
Old Feb 18, 2005 | 02:43 PM
Twospeed's Avatar
Twospeed
Default fog lights
I thank you for your reply:
I did what you guys said. I turned the headlight switch to the first position and the headlights come up but don't go on. Weather I hit the fog light switch or not. Whats up with htis? Help !
Twospeed's Avatar
Twospeed
Default fog lights
I did what you guys said. I turned the headlight switch to the first position and the headlights come up but don't go on. Weather I hit the fog light switch or not. Whats up with this? Help !
To foglights
