Replacing rear bushings with poly???
Old Feb 16, 2005 | 08:15 PM
silverz06vette's Avatar
silverz06vette
Originally Posted by RAFTRACER
There will be an air-gap between the two bushing halves, mount zerk fittings dead center of bushing bores.
thanks!!
I see what you mean:
Old Feb 16, 2005 | 09:18 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Wonder if I can drill them on the car?
Old Feb 16, 2005 | 09:31 PM
leaftye's Avatar
leaftye
John, you can drill them, but I recommend waiting till it's off the car so you don't have the risk of getting metal shavings in the bushings, and so you can round off the drilled holes on both sides....they'll be stress risers if left sharp....do you want your control arm to crack?
Old Feb 16, 2005 | 09:47 PM
see5's Avatar
see5
Yeah, but it is cast al and hole can be really small except where tapped for zirk.
Old Feb 16, 2005 | 10:09 PM
leaftye's Avatar
leaftye
Aluminum castings crack worse than forgings. Cracks grow at an exponential rate, so it doesn't matter that it's small because it'll grow REALLY FAST!
Old Feb 17, 2005 | 07:18 AM
see5's Avatar
see5
I would drill mine with no worries. Small hole, heavy casting.
Old Feb 17, 2005 | 07:21 AM
John Shiels
Guess I'll wait till they wear out. I'm not takng them out. How could I round the holes on the inside of the bore?
thanks
Old Feb 17, 2005 | 08:27 AM
leaftye's Avatar
leaftye
John, I haven't tried it yet, but if I get a chance to do that project, I'll let you know!
Old Feb 17, 2005 | 10:25 AM
silverz06vette
thanks
John, What you want to do is clean the inside and outside of the hole, deburring as we call it in the airline world.
http://cgi.ebay.com/ws/eBayISAPI.dll...874288154&rd=1
If you can find one that will fit inside of the arm, just turn it with your fingers.
You could also just take some sandpaper to smooth out the inside of the hole.
Old Feb 17, 2005 | 11:15 AM
silverz06vette
Just got off the phone with VBP and the poly kit is on backorder, they hope to have it to me by next w/e when I get my car tore down.
If they can't I will just cancel the order.
Old Feb 17, 2005 | 04:51 PM
XPC5R's Avatar
XPC5R
Try Ecklers, they had them in stock when VBP was out.
Old Feb 17, 2005 | 04:54 PM
RAFTRACER's Avatar
RAFTRACER
Good idea, call Nancy @ ext 424 and tell her Danny sent you
Old Feb 17, 2005 | 07:03 PM
  #33
silverz06vette
Ecklers is about $45 more than VBP.
VBP has a 10% off discount. I'll call ecklers and see if they will match the price.
Pic from both sites is the same.
Old Feb 17, 2005 | 10:40 PM
  #34
97coupechuck's Avatar
97coupechuck
Default suspension bushings
I'm in the middle of changing rear bushings right now, ordered bushing s from valentine, (discount arm of Ecklers) Got bushings with out the steel sleeve insert in them, didn't order them that way, they just came that way. mmmmmm, what a problem, factory bushings are molded onto the steel sleeve insert and you HAVE to cut, wittle, or do what ever you have to to remove the steel sleeves to install the new urethane bushings witch didn't come with them. I looked on line at Harbour Freight to see what tool he ordered and I don't think that tool will work that way. Looked around shop and I found some kind of gear puller to press out the old bushings, worked well. Looks like a small steering wheel puller.
Wonder why he taking out torque tube? I had to take mine out to replace broken coupler. When coupler broke at 135mph it did sojme damage so I replaced the whole torque tube. Chuck
Old Feb 18, 2005 | 01:14 AM
  #35
silverz06vette
Hope you got a good deal on those.
Taking the driveshaft out to inspect the 2 rear bearings that a few with the newer (01-04) driveshaft design have had problems with. I still can't find anyone with a 01 or newer C5 that has had rubber coupler problems.
Hope you upgraded to the newer TT/driveshaft.
