Headlight help
Old Feb 15, 2005 | 09:07 PM
Legends47's Avatar
Legends47
Default Headlight help
I changed my headlights over to T84's a couple of weeks ago and ever since my headlights stay open some of the times. There is no set pattern to them staying open. Does anyone know what controls the opening and closing of the lights? I know when you turn them on they open and when off they are supposed to close. Has anyone else had this problem and if so, what was required to fix the problem. I must have pulled a wire loose that is losing connection part of the time. Thanks, David
Old Feb 16, 2005 | 07:16 AM
Legends47's Avatar
Legends47
Brian at PFYC is sending me a plug in module that will take care of the problem. Thanks Brian for your help.
Old Feb 16, 2005 | 08:35 AM
Legends47's Avatar
Legends47
Brian at PFYC is sending me a wire module that will correct the problem. Thanks for you help. David
To Headlight help
