Top pops
Old Feb 15, 2005 | 09:14 PM
C501's Avatar
C501
Default Top pops
My '01's targa top pops when I have it on. If I unlock the rear lock on it while driving down the road, it stops popping.
I took the top off and removed the plastic piece around the latch. I checked the screws that hold it on and they were all tight. Next I took some silicone dielectric grease and greased the weather strips. That didn't do much of anything.
I'm not sure how to remove the plastic parts inside the car to see if there's a problem. Is there some sort of tool? Has anyone done this?
Old Feb 15, 2005 | 09:48 PM
killaz's Avatar
killaz
mine did the same. Take the driverside latch and pull it like your going to unlatch it, but only "unlatch it" like 1/4 inch. Made mine stop, hope it helps
Old Feb 23, 2005 | 08:04 PM
C501's Avatar
C501
Default I'll try
Thanks. I'll try that but the popping is coming from the rear of the top, not the front. I'm suprised this is not more common (or maybe everyone plays the stereo louder).
Old Feb 24, 2005 | 08:17 AM
leaftye's Avatar
leaftye
Hold up the interior plastic piece under the halo bar in the areas directly behind the roof pins. Does that stop the popping?
Old Feb 26, 2005 | 09:09 PM
timf1954's Avatar
timf1954
At the back of the removable top are two metal posts. Install some heat shrinkable tubing (available at electronics stores) over the posts and shrink the tubing carefully with a lighter or match. This should help a lot.
Old Feb 26, 2005 | 11:44 PM
cortex's Avatar
cortex
Lithium grease on connecting points.
To Top pops
