Have any of you ever had to change your parking lights? One of mine went out and I can't figure out how to get in there to change it without lifting it and taking a bunch of crap off the car. Is there an easy way to do this?
remove the black plastic headlight surround, ( Three phillips screws ) reach down , locate the socket, push in the tab and make a 1/4 turn Counter clockwise. Use a slight pressure to work the socket alittle because dirt may have made the socket tight.. use a back and forth motion increasing the pressure slightly each time..until you make a 1/4 turn.
Or,
Do what Evil-Twin suggested, but instead of reaching the bulb holder from beside the headlight surround, push the brake cooling duct out of the way and go in from that opening.
Or,
I don't suggest the "through the brake vent" method because several people have had to have their hand surgically removed...I know I could not get my hand in there...
