Help My Car Lost All Power
Old Feb 15, 2005 | 10:39 PM
turbo altezza's Avatar
turbo altezza
Default Help My Car Lost All Power
i lost all power then jumped the car, then i turned it off and went to turn it on again and the thing wouldnt start all the power was gone again. i tried to jump it again and it wouldnt work......it seems as if it may be the alternator???
Old Feb 15, 2005 | 11:01 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Do you have a stock battery?
that's the first thing you need to change...
Then check the voltage!
Chris
Old Feb 16, 2005 | 02:23 AM
turbo altezza
no i already replaced the stock battery about 5 months ago
Old Feb 16, 2005 | 02:27 AM
Lithium's Avatar
Lithium
check voltage once you jump it and see what it's reading, let the alternator charge it for a bit before you shut it off. Then see if it works. If not and its a pretty new battery try to charge it up or take it back
Old Feb 16, 2005 | 11:48 AM
COLORADO FRC's Avatar
COLORADO FRC
I had a problem much like this 2 weeks ago on a new Optima Battery, turned out to be a loose ground wire. Sometimes you have enough connection to turn over the started but once it archs it can tarnish the connection point and no longer make good contact to the grounding surface.
Old Feb 16, 2005 | 12:38 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
It could also be corroded battery cables. take both of them off the battery and clean them with battery cleaner.
Jeff
Old Feb 20, 2005 | 07:08 AM
Lithium's Avatar
Lithium
ever figure out what was wrong?
To Help My Car Lost All Power
