Quick timing chain question
Old Feb 16, 2005 | 05:59 PM
jers98vet's Avatar
jers98vet
Default Quick timing chain question
I'm in the middle of a cam swap and want to know if a ls2 timing chain will fit on my gears and if it any better than an ls1 chain. Thanks, Jeremy.
Old Feb 16, 2005 | 06:31 PM
99 The Hard Way's Avatar
99 The Hard Way
Yes it will fit, and it is a little beefier. I put one on my Z during a cam swap about a month ago. Used the old sprockets & fit perfect. Scott
Old Feb 16, 2005 | 06:41 PM
YO-EL's Avatar
YO-EL
Do an LS6 oil pump too! if you have a 97-00
Old Feb 16, 2005 | 07:05 PM
vettenuts's Avatar
vettenuts
Here is the difference:
Note: This photo was taken by somone on LS1Tech.com.
Old Feb 16, 2005 | 07:46 PM
2KREDVert's Avatar
2KREDVert
Or go a step further and go with a roller chain and sproket like the Rollmaster. Also Crane has one out I saw on Hot Rod TV. Much stronger than either of these.
Old Feb 16, 2005 | 08:03 PM
jers98vet's Avatar
jers98vet
Thanks for the replies. I am also installing a ported ls6 oil pump as well. I want to stick with the gm single roller chain so I dont have to change timing covers or shim the oil pump. My combo will not be seeing anything above 6500 rpm anyway. Jeremy
To Quick timing chain question
