Bad Wheel Bearing - How Tuff to replace?
Old Feb 17, 2005 | 01:04 PM
BostonVette's Avatar
BostonVette
Default Bad Wheel Bearing - How Tuff to replace?
I believe my left rear wheel bearing is shot.
I think the cartridge costs about $700 complete.
Is it possible to replace just the bearings?
How tough is it?
Who sells the bearings.
GM will only sell the complete assembly.
Anybody been there, done that?
Old Feb 17, 2005 | 01:10 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Temken sells the bearing complete for less the $175... then all you do is bolt it in... the rears are easy to replace compared to the fronts... hopefully someone will come along here and tell you where to order the temken bearing.
VR
Old Feb 17, 2005 | 01:58 PM
joemoia's Avatar
joemoia
Timken bearing/hub assys can be ordered through Autozone for approx. $150 ea.
Note, for later year C5's ('03, '04) the Autozone computer may stated that the bearing/hub assy is not available, but the bearing/hub assy is the same for all C5s.
Old Feb 17, 2005 | 02:50 PM
Patches's Avatar
Patches
Jake has tutorials on swapping both front and rear bearings. Check out the links on his site.
http://www.jakelatham.com/c5/misc/
Old Feb 17, 2005 | 03:56 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
bostonvette, give me a call 860-989-8972 steve, i can fix this no problem
Old Feb 17, 2005 | 06:51 PM
RoHo's Avatar
RoHo
Patches!!!!! As others have said, YOU ARE THE MAN-- Some Great info on this site, I have down loaded it all
THANKS MUCH
Old Feb 17, 2005 | 08:58 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Just bought a set from Auto Zone front 155 +- and got a 30 gift cert same for back and another 30 gift cert got them in 4 days
Old Feb 18, 2005 | 08:15 AM
BostonVette
Default Great Info
Thanks Guys,
That's just what I wanted to hear.
Thanks for the link to JakeLatham, I printed his tutorial
I guess I had the mistaken assumption that the bearings could not be seperated from the cartridge without damage.
Thanks again.
To Bad Wheel Bearing - How Tuff to replace?
