How to put fluid into differential
Old Feb 18, 2005 | 11:49 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default How to put fluid into differential
What are ya'll using to do this? I will have to drain and refill after my break in of the new gears. I've looked everywhere for that IV bag deal but can't find it. It was easy when the car was apart but since it will be together I figure it will be a little more difficult.
Do you think an enema bag would work? I came up with that by searching on Ebay. There are those fluid pumps on Ebay as well but I am a little skeptical of those. Is there some type of fluid gun like a grease gun?
Old Feb 18, 2005 | 01:57 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
It's really simple.. Just go to AutoZone (or whatever you have locally) and buy one of those <$10 gear lube pumps.. Works great.
Old Feb 18, 2005 | 02:28 PM
Mike Mercury's Avatar
Mike Mercury
another trick is to place a lentgh of clear plastic tubing on the bottles spout and squeeze the fluid into the differential... through the tubing.
Old Feb 18, 2005 | 04:09 PM
Cajundude's Avatar
Cajundude
An hour or so after posting this I figured out the keywords "suction gun". That's what I need. Going to New Orleans this weekend so I'll stop by Harbor Freight. They have some cheap ones.
Old Feb 18, 2005 | 04:30 PM
dmtnt's Avatar
dmtnt
St. Jude Donor '03-'05-'06 & '12
Home Depot has one too, hooks up to your drill and fills the diff in no time. Works great for the trans too.
Old Feb 18, 2005 | 04:37 PM
jnsfeeney's Avatar
jnsfeeney
Don't overly complicate a simple process. The $7-$10 fluid pump from any auto parts store is the way to go.
Old Feb 18, 2005 | 05:19 PM
LoneStarFRC's Avatar
LoneStarFRC
Yup. It's what is also referred to as a "Hycar" type pump. Simple metal tube with a hand operated plunger and a clear vinyl hose on one end. A company by the name of Plews has been making them for years. The one I have works great. HTH
Robert
Old Feb 18, 2005 | 06:43 PM
jmzvet's Avatar
jmzvet
I used a $12 suction pump to do my trans & diff today. Pretty simple job.
Old Feb 19, 2005 | 06:47 AM
viper punisher's Avatar
viper punisher
[QUOTE=Do you think an enema bag would work? I came up with that by searching on Ebay.[/QUOTE]
Creative use for an enema bag I must say. Just wait 'till your wife catches you under the car with that!
Old Feb 19, 2005 | 07:13 AM
see5's Avatar
see5
If you have an air compressor:
Drill two holes in the top of the fluid bottle and inset the two lengths of clear tubing. Make sure one lenght goes to the bottom of the bottle> put that tube into the fill hole on the rear/trans. Push the other hose end into your air gun and very gently pressurize the bottle. Works slick. I have used this to pump rear end fluid, gear oil and all sorts of thick and thin fluids.
Old Feb 19, 2005 | 07:18 AM
USA-VET's Avatar
USA-VET
Old Feb 19, 2005 | 11:03 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Feb 20, 2005 | 10:14 PM
Cajundude's Avatar
Cajundude
Yea, I'd have to order the enema bag online because there is no way I'd actually go into a store and buy one of those. I did go to New Orleans this weekend and stopped by harbor frieght and picked up a couple of suction guns.
Old Feb 21, 2005 | 01:24 AM
Vette#2's Avatar
Vette#2
How about a Douch bag ?
Old Feb 21, 2005 | 08:35 AM
Mr. Jones's Avatar
Mr. Jones
get the fluid pump usa-vet shows.
I have used the same one for diff and trans fluids.
Old Feb 21, 2005 | 08:44 AM
IMQUIK's Avatar
IMQUIK
I built me this.
Old Feb 21, 2005 | 09:00 AM
kg54trains's Avatar
kg54trains
Default Fluid exchange...
Auto Zone and Pep boys have .com inventory for online orders. Both have several ways to handle exchange.
To How to put fluid into differential
Old Feb 21, 2005 | 09:16 AM
Cajundude's Avatar
Cajundude
Yea well, I'm not touching one of those much less going somewhere and buying one!
Old Feb 21, 2005 | 09:27 PM
RonJ's Avatar
RonJ
Now, that sounds slick!!!
Ron ....
Old Feb 21, 2005 | 10:01 PM
Cary's Avatar
Cary
AMSOIL Hand Pump for Bottles part# G2039
Fits AMSOIL quart bottles, 1-gallon containers and 2.5-gallon containers. Guarantees efficient, quick dispensing of AMSOIL gear oils, transmission fluids and any oil that may need to be pumped. Great for fluid fills in differentials, transmissions, transaxles, boat lower units and boat sterndrives. $9.95
A friend of mine helped me change out my rear diff fluid yesterday. The hand pump worked great! BTW, make sure you have a 10 mm allen wrench.
