Downshift to 1st problem
Old Feb 18, 2005 | 12:22 PM
Florida2000's Avatar
Florida2000
Default Downshift to 1st problem
M6: had a problem shifting into 2nd this morning - popped out of second then wouldn't go in easily when I tried again, now I can seem to downshift into first. It seems like I have to pull the shifter way left to get it in gear, wont go on 1st try but will on the second attempt.
Clutch feels normal. Any ideas? Are there any adjustments that could be needed? or could Syncros be damaged or need replacing?
Old Feb 18, 2005 | 01:13 PM
DickieC.99's Avatar
DickieC.99
not sure about your earlier problem about getting it into second but when i'm having a hard time getting into first I will put it in another gear (second) and then it goes right in to first.....
Old Feb 18, 2005 | 01:34 PM
Darkness's Avatar
Darkness
Might be the syncros going out.
Old Feb 18, 2005 | 02:48 PM
Monster231's Avatar
Monster231
Im not sure your suppose to downshift into first, The trans may be blocking you out
Old Feb 18, 2005 | 03:34 PM
yellow01's Avatar
yellow01
Downshift at what speed?
When you say trouble getting into 2nd - what did it feel like - just didn't engage? Didn't feel like it went far enough? Any apparent grinding?
Does the shifter feel loose? (like something's recently changed?) Could be a problem with the shifter itself - that'd be easy.
Could be synchros as mentioned. 1-2 synchros take a beating on the street because we all love those nice jaunts up to the speed limit...the 1-2s went out on my '01 after 17k (albeit with some abuse - I was much easier on the new ones)
Old Feb 18, 2005 | 04:22 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
What speed? There is no reason you should ever downshift into first gear. Even if your going 2 mph it would be difficult.
Old Feb 18, 2005 | 04:39 PM
Florida2000
popped out of gear, grinding noise, tried to get it back into 2nd, more grinding, 3rd time OK
car always downshifted into 1st real easy, I usually downshift in parking lots etc, at say 15 MPH -I have never had anything but smooth and easy downshifts, not if feels completely different (20 K on a 2000 btw)
Old Feb 18, 2005 | 04:42 PM
Florida2000
Gotta disagree, car has never had a problem downshifting when pulling into a parking lot for example...always real smooth and easy...manual says you can downshift into 1st at quite a high speed, cant remember exactly what it says, never tried it above 10-15mph
Old Feb 18, 2005 | 04:43 PM
Florida2000
any idea what the cost to replace is?
Old Feb 18, 2005 | 07:46 PM
Lithium's Avatar
Lithium
when i go over speed bumps i slow down to a crawl and put it into first from whatever gear i was in...never had any problems gettin into first doin that
Old Feb 18, 2005 | 07:56 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I do it all the time...and it's quite effortless.
If you're in the proper speed range, I can't imagine why you shouldn't or couldn't. No different than downshifting to any other gear.
Old Feb 18, 2005 | 08:14 PM
EHS's Avatar
EHS
I think that's reverse that has the lock-out.
The owner's manual recommends shifting into 1st whenever you need to, for example after you've been driving a while, you stop, and they suggest you downshift into 1st to get going again.
Old Feb 18, 2005 | 08:26 PM
EHS's Avatar
EHS
Not so -- as a matter of fact, you might want to try and ease the shifter into first just as you come to a complete stop. Put some pressure on the shifter below about 3-5 mph as you stop, and notice how smoothly it goes into first.
Every driving school teaches that, and every one of the new sequential gear shift boxes will, in auto mode, downshift into first while the car is still rolling. That's the whole point -- it's easier to get into first while you're still rolling a bit.
And, oh, I've got about 300,000 miles of manual transmission driving, and have yet to replace either a clutch, or a syncro. I know what works.
Old Feb 18, 2005 | 08:59 PM
BigBlue's Avatar
BigBlue
Sounds like the synchros.
To Downshift to 1st problem
