Ca. smog, CAM, Question?
Old Feb 18, 2005 | 03:23 PM
C54DAZ's Avatar
C54DAZ
Default Ca. smog, CAM, Question?
Is any body passing California smog test with a 228/228 .588/.588 or anything close to these spec??? Or is 224/224 about the limit? Thanks.
Old Feb 18, 2005 | 04:28 PM
X-ZZ4's Avatar
X-ZZ4
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Since I could not find a single CARB approved LS1 cam I'm assuming that your chances of passing with EITHER are directly proportional to the ignorance level of the smog tech.......
Old Feb 18, 2005 | 04:32 PM
bayarea's Avatar
bayarea
I just registered in lake county so I dont worry about it
Old Feb 18, 2005 | 07:05 PM
7.0sc SuperVette's Avatar
7.0sc SuperVette
From: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
Default Lake County?...
What's the story on "Lake County"?
Roy
Old Feb 18, 2005 | 09:42 PM
2ndVette's Avatar
2ndVette
well, there's always one in the basket of apples like this comment. Never mind that the LS7 will be passing with flying colors at 591" lift. Yes.it is true that if you dare use anything that is not pure OEM, you run the risk of technically violating the emmisions laws. And, that is true, even if you have CARB numbers in place. The law doesn't necessarily approve of multiple parts all sporting CARB numbers as those certifications were achieved against a stock Vette. The perceived safety of a CARB number really only applies to the use of one part with that certification.
Old Feb 19, 2005 | 11:46 AM
Malibu Vette's Avatar
Malibu Vette
Default ca cams
I just did a pre-test with headers, hi flo cats, AFR heads, Haltech Trap, and 224/228 @ 114 cam. It failed the shiffer by 5 parts HC. I have confidence that I can tune that out. I would think a 224@114 with a decent tune should pass the sniffer. The key is to get a tech that doesnt look overly hard at things. The Koos headers after time turn gold and really dont stand out. The under car check he did see cats, The heads didnt get a second look, the CAI he didnt care about. Just my experience.
Old Feb 19, 2005 | 11:48 AM
ROD BROWN's Avatar
ROD BROWN
Default I passed smog
I passed smog with a stage 2 engine and stage 2 heads.Look below and you can read my mods.The secret is in the tuning.I passed the smog test last Monday,and I don't have any worries as log as Andy is alive and kicking.
Old Feb 19, 2005 | 01:02 PM
davette's Avatar
davette
220/220, .581, 114lsa.... passed sniffer with room to spare.
I would think a 228 could pass with a proper tune. As other people are saying, the tuning part is the key.
LAKE COUNTY does NOT require smog checks unless ownership changes.
People get mailboxes there to register their tricked out cars.
Old Feb 19, 2005 | 03:04 PM
bayarea's Avatar
bayarea
Roy
my uncle lives there, and hes never smogged any of his cars. I also checked with dmv and lake county does not have to report to any smog. so with the g5x3 cam I'm gettin installed this tuesday it will work out fine.
Adam
To Ca. smog, CAM, Question?
