question regarding header fitment
<br>
fit on my 2000 frc? Here is my build date...
Build Date : 11/05/1999 Build Plant : 1Y5Y - BOWLING GREEN
i have a bad pic of my stock ones now i just got to get it hosted real quick. Supposedly the ones above are for a 2000, do you guys think they will fit?
Look at engine Passenger side. See where Air injector tube is located.
2 choices...Your pic shows connection at the rear tube. Other choice is between 2nd & 3rd tubes.
See which is on your ride. Then you can tell if it would fit.
BTW you would need to shorten both side of the forward bolts going into the headers by 5/16" as the stock length bottoms out on the air tube connector (on the later model one between 2-3 outlets)
Hope this helps
