Front End Squeaking on my C5
Old Feb 21, 2005 | 10:29 AM
schnaker's Avatar
schnaker
8th Gear
Default Front End Squeaking on my C5
Anyone had this problem? Dealer told me could be the front shock mounts.
Old Feb 21, 2005 | 10:36 AM
jimcork1's Avatar
jimcork1
Default Squeek
I have a front and rear squeek but it looks like the sway bar bushings. See post on sway bar grease.
I plan to pull the front and rear sway bar,, clean lube and then check it out.
There is also a squeek that can come from the front spring pads. I just had mine replaced. However they installed the pads dry and now they don't squeek,, they groan like dry rubber. Out of the frying pan into the fire. My car still has about 1 month left on warranty but I am afraid the dealer still won't get it right. So I will pull the bars and spring if necessary. best of luck.. 99 Nassau Blue
