Water Temp Question...
Old Feb 21, 2005 | 09:28 PM
debmwb's Avatar
debmwb
Default Water Temp Question...
I have an '04 Coupe with the stock thermostat. The water temp normally stays around 190-192 at 55-60 mph and 196-198 stopped when running with the A/C on. After taking the top off...I do like that feature...and turning the A/C off, she cruises at normal temp but cycles up to 205-207 while waiting at lights. In the driveway while putting the top back on the temp went up to 217, but made a retreat once I turned the A/C back on. I'm wondering what other experiences are?
Old Feb 21, 2005 | 10:35 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Your temps are normal. Using the AC turns on the fans before their set point which is just shy of 230. If you don't turn on AC sitting on a hot day, the temp will go up to about 227-228 or so and the fans will kick on and lower temp about 10-12 degrees.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Feb 21, 2005 | 10:42 PM
GrayC5's Avatar
GrayC5
Your temps are all well within normal range.
Old Feb 21, 2005 | 11:01 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
These are aluminum block engines. They like/need to run warmer than their iron block predecessors.
If it worries you, have the fans programmed to turn on 5-10 degrees earlier, and possibly go to a slightly cooler thermostat (since you live in a mild climate).
Old Feb 21, 2005 | 11:14 PM
debmwb's Avatar
debmwb
Kewel!! I thought they were okay. I just hadn't run with the top and the air off for some time.
Old Feb 22, 2005 | 07:34 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Here is the stock PCM programing for the fans
Depends on the model year...
For later model years:2000+
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
For early model years:
Low speed fans come on at 219,high speed fans come on at 228,low speed with a/c on...
Old Feb 22, 2005 | 11:18 AM
03LingenfelterC5's Avatar
03LingenfelterC5
What does a 160 degree thermostat do for you? Lingenfelter is putting that in along with other engine work this week on my roadster.
Old Feb 22, 2005 | 11:29 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
By itself... nothing. When combined with lower turn-on temps of the fans, it will lower your coolant operating temps. If that is a Lingenfelter F/I system you are having installed, they like to run cooler to avoid detonation problems under boost. They will probably recommend cooler plugs for the same reason.
Old Feb 22, 2005 | 12:03 PM
ErnieD's Avatar
ErnieD
St. Jude Donor '16-'17,'19
I have a 2004 coupe and it will get all the way up to that 235-degree high-speed-fan turnon point under adverse conditions. I.e., if it's over 100 degrees and I've just come off a 50-mile hiway run, (windows down & no air conditioning), then a five minute wait at a traffic light, temp goes to 235 and the high speed fan comes on. Under more normal conditions, temps are just about as you described for your car.
Have you resolved your pinging issues? If so, how? Mine runs fine on 93 or 94 octane, but will audibly ping on our California 91. Only changes are a GHL catback and a Z06 airbox lid (with stock paper filter).
Ernie
Old Feb 22, 2005 | 05:04 PM
Evil-Twin's Avatar
Evil-Twin
Originally Posted by black04
I have a 2004 coupe and it will get all the way up to that 235-degree high-speed-fan turnon point under adverse conditions. I.e., if it's over 100 degrees and I've just come off a 50-mile hi way run, (windows down & no air conditioning), then a five minute wait at a traffic light, temp goes to 235 and the high speed fan comes on. Under more normal conditions, temps are just about as you described for your car.
Have you resolved your pinging issues? If so, how? Mine runs fine on 93 or 94 octane, but will audibly ping on our California 91. Only changes are a GAL cutback and a Z06 air box lid (with stock paper filter).
Ernie
heat will cause KR and decrease in performance.. keeping the car in the sweet spot will help ( 190/200 ) coolant, and (200/210) oil temp...you can do this with the help of a lower stat and reprogrammed fan settings. It is important to make sure your ac condenser and radiator fins are as clean as possible for cars in CA using 91 octane, cleaning the radiator should be part of yearly maintenance... in the most adverse case a higher capacity performance radiator will work, like a "Be Cool" or one of the other performance radiators.
Old Feb 22, 2005 | 09:28 PM
ErnieD's Avatar
ErnieD
Thanks for the advice. If I can find a thermostat that drops temps about 10 degrees (182 vs. 192) at hiway speeds, I will probably give that a try ...along with reprogramming fans downward about 10 or 15 degrees, of course. I feel that 160 degrees is a bit low, but it seems that thermostats spec'd at 160 usually control to some higher temp under cruising conditions. Do you know of any specific source of one that would run out at about 182?
Debmwb, what's the status on your pinging issues?
Ernie
Old Feb 22, 2005 | 10:42 PM
debmwb's Avatar
debmwb
Ernie
I have reached nirvana! (and perma-grin)! I have 3% more timing in with 6% enrichment at both RPM settings. No pinging....lots of wheel spin, but no pinging!
Old Feb 23, 2005 | 07:43 AM
Evil-Twin's Avatar
Evil-Twin
A thermostat change takes less than five minutes, start to finish. I run a 160 F stat mid April, May, Jun, July, Aug, mid Sept, with lower fan settings. I run a stock stat, mid Sept through the winter until mid April.
I do this twice a year, without any issues. Car is five years and 58,000 miles old.
Old Feb 23, 2005 | 11:03 AM
ErnieD's Avatar
ErnieD
Sounds like just running a hair richer fixed your pinging problem. I think mine would be ok too if I just had 93 octane available on a regular basis.
Thanks for the info.
Ernie
Old Feb 23, 2005 | 11:43 AM
ErnieD's Avatar
ErnieD
Yeh, you're right ...it's only a few minutes and a few bucks to try this out. Although it doesn't ever get very cold here in No. central California, it'll still be a month or two before it gets hot enough to really see if lower coolant temps will cure the pinging. I may pick up a Predator in the mean time so I can adjust fan settings and have some minor control over ignition timing if that proves to be required to eliminate the pinging.
Ernie
To Water Temp Question...
