Removing wheel driveshaft
Old Feb 22, 2005 | 02:27 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Removing wheel driveshaft is a piece of cake
I think I may have nicked my output shaft seal and have noticed a little leak coming from my passenger side of the differential where the wheel driveshaft stabs into the diff. I haven't removed just the shaft before. Is there any hidden tricks to it? Maybe I didn't seat it all the way when I put the diff back in but I'm going to install a new seal anyway. Thanks in advance! On my way home and by the dealer now.
Old Feb 22, 2005 | 04:41 PM
kromberg's Avatar
kromberg
Keith
Old Feb 22, 2005 | 04:44 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I will match you one and raise you
VR
Old Feb 22, 2005 | 05:05 PM
Dope's Avatar
Dope
Resident moron
Nope.
Remove wheels. Disconnect the upper control arm from the chassis (2 18mm bolts at the top), and the upper shock from the chassis (2 13mm bolts again, at the top). Now you should have some slack. Literally yank the top of the rear spindle/brake assembly hard a few times and it'll pop the half-shaft out of the differential. Viola.
Putting it back in is a little bit tricky. Nothing special to it but it can be a pain getting the splines to line up and getting your arms in there and putting pressure on the halfshaft to 'pop' it in..
Dope
Old Feb 22, 2005 | 06:04 PM
Cajundude's Avatar
Cajundude
Didn't feel like waiting any longer for replies but ended up doing it pretty much like Dope said. Didn't take more than 30 min. Piece of cake. My seal looked good but I went ahead and replaced it anyway. Hope it cures the leak.
Old Feb 22, 2005 | 06:25 PM
usd2sing's Avatar
usd2sing
my little rocket leaks also (both sides)...thanks for the how too...
question....i over heard somebody talking about a "newer" seal for the diff's...one that lasts longer...anybody heard or know of this???
who makes it...where to buy it??? part numbers???
thanks,
dan
Old Feb 22, 2005 | 07:00 PM
Cajundude's Avatar
Cajundude
The part number I got from the dealer 2 hours ago is 88996703.
Old Feb 22, 2005 | 07:58 PM
usd2sing's Avatar
usd2sing
hi, thanks...is this the new and improved seals???
Old Feb 22, 2005 | 10:15 PM
Cajundude's Avatar
Cajundude
Not 100% sure but from other threads I have read, yes they are.
To Removing wheel driveshaft
