Emblem Problem
Feb 23, 2005 | 04:05 PM
Emblem Problem
I have a Emblem with the two prongs And I want to mount this between the seats I cut the prongs off What can I use to to mount this? Is there any really good 3M tape out there that is thin in thickness So that the emblem is flush to the console
Reason: spelling
Feb 23, 2005 | 06:39 PM
or for 3M tape.
RTV might work, just whatever you choose !
Feb 23, 2005 | 08:12 PM
You can also get the double sided 3m tape at NAPA.
Feb 24, 2005 | 12:16 AM
Ecklers sell a waterfall emblem without the two prongs that already has stickum on it!
Feb 24, 2005 | 12:27 AM
I need the 50th Anniversary emblem with out the 50th Inside it
Feb 26, 2005 | 07:38 PM
Oh you mean the "painted" gray one.
Feb 26, 2005 | 08:23 PM
The strongest two sided tape is the 3M "VHB" (very high bond) - once you stick it to a clean surface it bonds tight -
Feb 26, 2005 | 09:16 PM
Quote:
Do you know Where I can get it
Feb 26, 2005 | 09:17 PM
Feb 26, 2005 | 09:36 PM
From: Spread The Virus!!!!!!! Opie and Anthony XM Satellite Radio
silicone adhesive. spread a small amount over the entire back side, just a very thin coat. press it on and use some masking tape to hold it in place. after it is set, only a couple hours, any that squeezed out can be rubbed off with a q tip.
Feb 27, 2005 | 12:25 AM
just get a factory emblem that was designed for the rear deck. it already has the adhesive and does not have the bumps. found the cheapest on ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33643
Feb 27, 2005 | 01:44 AM
Quote:
PM sent Moonie.
Feb 27, 2005 | 05:07 AM
oops...missed this part earlier.
Feb 27, 2005 | 01:49 PM
can't you use some 3M spray-tack ?
