Grounding a Battery Tender
Old Feb 25, 2005 | 06:25 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Originally Posted by vetdude
The instructions that come with the Battery Tender Plus specifically state, do NOT connect negative clip to anything but the negative post on the battery.
Yes But i called the company when i got the battry tender and they told me i can do that.
Old Feb 25, 2005 | 10:52 PM
Cat Eye Blue's Avatar
Cat Eye Blue
I connecte mine to the screw that holds that rubber hood stopper. No problems. Green light is on and all is well!
Old Feb 26, 2005 | 01:12 AM
xlr8shn's Avatar
xlr8shn
+ red to the red wire on back of the alternator
- black to the top alternator mount bolt
Old Feb 26, 2005 | 04:32 AM
C5XTASY's Avatar
C5XTASY
Originally Posted by wwashing
Well, of course the instructions with my automatic charger are different. My charger (Griot's Garage Automatic Charger) says "connect the Negative (BLACK) clamp to the vehicle chassis, heavy guage metal part of the frame, or engine block, away from the battery". I connect mine to that metal tab that sticks up from the water pump.
The reason this is suggested is that there is a chance that connecting the negative terminal could result in a spark. And, since vented battries could be releasing flamable gases, the safe route for the manufacturer is to suggest attaching the ground away from the battery.
Why not just plug the tender in AFTER it's connected to the battery?
Ed
Old Feb 26, 2005 | 11:20 AM
white top's Avatar
white top
Ground mine to the bottom of the rubber hood bumper O terminal bolted on there. the positive I bolt to the hot terminal that comes off the side of the fuse box. This way you can simply plug in the tender to the wire harness that comes with the tender.
Jerry
Old Feb 26, 2005 | 11:27 AM
CFJ98's Avatar
CFJ98
I bought a trickle charger from Sears and the instructions said to ground the negative clip to the car's chassis. I hooked the charger that way, got a green light indicating the battery was fully charged, and went on with my businesss.
A couple of months later I tried to open the car doors with my FOB and the battery was completely dead, but the green light was still on. It wasn't until I hooked the negative (black) clip of the battery charger to the negative battery post that the battery was charging. Once I did this the amber light on the charger went on indicating the battery needed charging.
In my experience the battery charger clips should be hooked directly to the battery.
Old Feb 26, 2005 | 01:23 PM
wwashing's Avatar
wwashing
Ed
The instructions say to do this also.
