Question about Locktite.
Old Feb 24, 2005 | 04:48 PM
DanielW's Avatar
DanielW
St. Jude Donor '04-'05-'06-'07-'08
Default Question about Locktite.
The two bolts that hold the brake caliper to the steering knuckle, when putting them back it says to use Locktite. Is any color fine or is there a specific one to use?
Old Feb 24, 2005 | 04:54 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
I use blue... it doesnt become like cement, like the red, the red is what is used on the bracket bolts from the factory.. the blue is a semi hardened anti vibration thread compound.
Old Feb 24, 2005 | 04:57 PM
DanielW's Avatar
DanielW
Thanks for the quick reply.
I think there was some red on the drain plug on the MN6 tranny. I didn't put any on when i put it back. Should I worry
Old Feb 24, 2005 | 05:03 PM
Classical Glass's Avatar
Classical Glass
Default Locktite
Use Blue Locktite #242. Medium strength, from aprox 1/4" to 1/2".Under 1/4" 6-32, 8-32,10-32 etc use Pink Locktite #222. Be sure all parts are clean and oil free that's very important.On critical fasteners use a Locktite primer first.
Old Feb 24, 2005 | 07:13 PM
leaftye's Avatar
leaftye
If you use Locktite blue, make sure it's actually the Locktite brand. Not all Locktite like products use the colors the same way.
Old Feb 24, 2005 | 08:05 PM
CHJ In Virginia's Avatar
CHJ In Virginia
It is very important to get all the old lok-tite off of the bolt prior to installation. Use a wire wheel on a grinder or something that will get to the bottom of the threads. Also get the correct size tap and chase the inside threads if you can. Clean surfaces are a must for the product to work properly.
Old Feb 25, 2005 | 05:12 AM
vettenuts's Avatar
vettenuts
That isn't Loctite, it is a red silicone for sealing. I wouldn't use Loctite on this application.
Old Feb 25, 2005 | 07:37 AM
dmtnt's Avatar
dmtnt
St. Jude Donor '03-'05-'06 & '12
For the caliper brackets, I use red high strength (not permanent). At the temperatures those calipers can reach (especially if you track the car), blue will be useless.
As CHJ stated, clean the bolts up well before applying new loctite.
Old Feb 26, 2005 | 03:58 PM
DanielW's Avatar
DanielW
thanks for the replies guys, but i couldnt even get the old bolts off. i can't even fit my damn torque wrench over there. i think i might just take it to a brake shop. even if i do take out the bolts, i can't be sure that i will torqe them properly, and i don't want my caliper coming off at 100mph+
Old Feb 26, 2005 | 08:31 PM
leaftye's Avatar
leaftye
Did you use a 16 mm to lock the pin that's behind the bolts?
To Question about Locktite.
