headers
Old Feb 25, 2005 | 12:31 PM
Jim D's Avatar
Jim D
Default headers
I know this must have been discussed before, but here we go. Is there much difference betwwen 1 3/4 and 1 7/8. Some of the peformance mags , say there isn't much between stock and after market. The reason I'm asking is Jet-Hot sells there 1 3/4 coated headers for 599. thanks Jim.
Old Feb 25, 2005 | 02:13 PM
Mitch C's Avatar
Mitch C
If you have a stock displacement 346 the 1 3/4 headers are a better choice in most cases. The 1 7/8 headers are better suited to engines with larger displacements. You can use 1 7/8 headers on a 346 but in some cases you will get a reduction in torque.
Old Feb 25, 2005 | 02:16 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
The 1 7/8 inch headers are for larger engines. If you are running the 5.7 liter ls1/ls6 then you should buy the 1 3/4 headers.
To headers
