Heads with a "small cam"
Old Feb 25, 2005 | 11:49 PM
1999PewterCorvette's Avatar
1999PewterCorvette
Default Heads with a "small cam"
A little while ago I posted a thread asking what heads would be a good choice for me. I would like to shoot for 400 rwhp. I have air intake, mallett exhaust, LT headers, and a 221 .558 lunati cam. Everyone seemed to agree that LS-6 heads would be just fine. The AFR's , although nice, is probably a little more than I need (and more expensive). Ok so heres my stupid question: When they said LS6 heads, does that mean just throw some stock ones on?? Or do they mean CNC, ported polished, etc??? Will I get very much improvement if I bought a set of Z06 heads and just threw them on as is? And will I need anything else-- I already have chromoly hardened pushrods and comp 918 springs. Do I need any other accessories?
thanks guys
Rob
Old Feb 25, 2005 | 11:55 PM
99SilverC5Coupe's Avatar
99SilverC5Coupe
I'd add an LS6 intake as well....regarding the heads.. I don't know but I did see a couple good deals in the for sale section recently... fiqure you will spend a couple of dollars getting used heads tanked and surface milled....and 02 and up LS6 heads will be around $800
TEA Heads
Patriot Heads
not endorsing either one ... in your quest for 400rwhp
the 5.3s should give you a bump in compression....
Old Feb 26, 2005 | 12:04 AM
ArKay99's Avatar
ArKay99
If you want 400rwhp with that cam you will need P&P CNC'ed heads. IMHO.
Old Feb 26, 2005 | 03:37 AM
Mitch C's Avatar
Mitch C
When you asked what heads to get awhile ago. The members that answered you must have meant that you should use stock LS6 heads. Because if you buy a set of stock LS6 heads and pay to have them CNC or ported by hand ported. You would be spending about the same amount of money it would cost to buy AFR heads.
Old Feb 26, 2005 | 05:55 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I think the Stock LS6 heads are about 20 HP more than the stock LS1 heads.
With that cam, your bolt ons, LS6 manifold and cam, you'll be close to 400 RWHP. Im talking either JUST over it or JUST under it depending on the tune and dyno. My bet is just under the 400 RWHP
Old Feb 26, 2005 | 07:07 AM
JerriVette's Avatar
JerriVette
Go for the AFR heads if your spending the money to buy ls6 heads and having them port and polished....'
The valvetrain upgrades on stock ls6 heads brings your cost to about 1200 if you do it right with dual valve spring kit..
If your spending the money on the head installation already rather than go stock ls6 with valvetrain upgrade, or the ported ls6 heads you might as well spend the extra 900 for the best heads out there. (afr)
If you want inexpensive heads you should just go with ls1 heads that have been ported and polished...with dual springs...
AA Andy has nice products if your self installing but my recommendation is to go with dual valve springs no matter what...
Crane, or comp 921's duals would be my choice.
JMO
Old Feb 26, 2005 | 09:13 AM
6Speeder's Avatar
6Speeder
Instead of spending the big bucks for a set of AFR or Z06 ported heads, look into a set of 5.3 truck heads, with big valves, ported. They will cost less, give more compression, and with a small cam flow very well. See my sig, I'm running them with a smaller cam: 218/218 dur, 114 lsa, .58" lift.
Old Feb 26, 2005 | 04:33 PM
1999PewterCorvette
So what kind of power increase would I see with staying with LS1 heads that are cnc'd --like the ones from lingenfelter or Andy's????
they run around 1500 bucks-- would it be much of a gain with my 221 .558 cam?? Just want to have some idea
Old Feb 26, 2005 | 04:47 PM
rockgt302's Avatar
rockgt302
St. Jude Donor '05
Look for phils c5 vette, he has a set of 5.3 heads for $600.
nevermind,I should of read the whole post, he responded here already.
To Heads with a "small cam"
