Wheel sensor question.
Old Feb 26, 2005 | 03:52 PM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
Default Wheel sensor question.
Will the car throw a code if I throw on a set of wheels without sensors?
And if it will throw a code, can it be turned off with a TechII?
Thanks, Pete
Old Feb 26, 2005 | 03:55 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Yes, if the car isn't a Z06.
Tom
Old Feb 26, 2005 | 04:00 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
If you have a Z06 like your username and avatar imply, no. The TPM system isn't enabled on Z06's, and Z06's didn't come with sensors in the wheels..
If you have a normal C5...then yes, you'll get a warning message at startup. Press reset and it goes away.
The TPM system can be disabled via Tech-2 on 2001-newer C5's only.
PeteZ06's Avatar
PeteZ06
Yes what? Yes it will throw a code or yes it can be turned off???????
Old Feb 26, 2005 | 04:02 PM
PeteZ06's Avatar
PeteZ06
Thank you Y2K.
Old Feb 26, 2005 | 07:12 PM
DirteeDave's Avatar
DirteeDave
I think I also read that after 50 starts, the error message no longer displays on the DIC.
Old Feb 28, 2005 | 11:14 PM
texasredc8's Avatar
texasredc8
Not unless the "problem" is corrected. You'll get the error codes about every 10 minutes.
Old Feb 28, 2005 | 11:17 PM
DirteeDave's Avatar
DirteeDave
What I read was that the codes would still be thrown but no longer displayed on the DIC.
Old Mar 1, 2005 | 10:52 AM
texasredc8's Avatar
texasredc8
The warnings continue to be relentlessly displayed on the DIC at engine startup, every 10mins or so, and at engine shut down.
Unfortunately I have first hand experience of this pleasure. My TPM system is enabled, but I haven't had the time to install the sensors yet in the wheels.
To Wheel sensor question.
