problems
Old Feb 27, 2005 | 04:23 PM
Hotshot's Avatar
Hotshot
Default problems
I need help, I just purchased a 97 corvette with 58000 miles on it.
While driving from houston the following things happen.
ABS light came on
Traction Control led came on
Check Gauges light came on
Oil pressure, temp, and fuel gauges work
Reduce Engine power appeared on the lcd display
check tire pressure appeared on the lcd display
low fuel appeared on the lcd display
the car continue to run but at a reduced speed
What can this be......
Old Feb 27, 2005 | 04:55 PM
Special K's Avatar
Special K
ABS light came on
Battery or maybe alternator would be the first things I would look at.
Bob
Old Feb 27, 2005 | 05:11 PM
servohead's Avatar
servohead
ditto. Easy fix.
Old Feb 27, 2005 | 07:49 PM
Hotshot's Avatar
Hotshot
Korreck, Servohead
I had the battery and alternator checked at Autozone, checkout ok...by the gauges mentioned above do not work....Hotshot...
Old Feb 27, 2005 | 07:50 PM
Hotshot's Avatar
Hotshot
Korreck, Servohead
I had the battery and alternator checked at Autozone, checkout ok...by way the gauges mentioned above do not work....Hotshot...
Old Feb 27, 2005 | 08:03 PM
Special K's Avatar
Special K
Korreck, Servohead
I heard ya the first time
It has to be a voltage problem. Start checking all the grounds. Good luck.
Bob
Old Feb 27, 2005 | 08:29 PM
ronwc's Avatar
ronwc
Check and clean the two grounds behind the headlight on the chassis -
Old Feb 27, 2005 | 09:22 PM
Hotshot's Avatar
Hotshot
Thanks, guys.....
Old Feb 27, 2005 | 10:12 PM
servohead's Avatar
servohead
Yeah let us know how the grounds look behind the headlamps........ Someone show him to the thread that Bill Curlee had on cleaning those... (I can't find it) And if cleaning those grounds doesn't work, then there are other bad grounds, or your wiring harness under the battery has been damaged due to a leaking battery. To put your mind at ease I can bet you that there's probably no reality for each of the the fault messages that you were getting. You'll fix it.
To problems
