Need help taking the calipers off.
Old Mar 3, 2005 | 11:33 PM
DanielW's Avatar
DanielW
St. Jude Donor '04-'05-'06-'07-'08
Alright. The fronts are done, but the rear sumbitches aint comin off. I got one of those ratchets with pivoting heads and i put a conduit pipe on it to get more leverage but when i press down on it just jumps off the bolt. plus that brake line is right next to that top bolt. might just go to a local mechanic so he can get it up on a lift and get those bolts from underneath. I was trying to get the rears off for an hour. they won't budge.
Old Mar 4, 2005 | 12:42 AM
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
To get mine off, I took my 18" breaker bar, a 6 point socket (won't slip on
the bolt head), set the socket on the bolt head w/wrench attached, laid
myself down, feet toward wrench, and broke it lose pushing wrench with
my foot. Tightened them back the same way, my torque wrench wouldn't
fit either.
Old Mar 4, 2005 | 01:58 AM
C54DAZ's Avatar
C54DAZ
Default rear bolts
Me too. sat my but on the ground and kicked em loose...
Old Mar 4, 2005 | 02:01 AM
DanielW's Avatar
DanielW
You guys lift the whole rear end or lift each side at a time.
Old Mar 4, 2005 | 05:48 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
When I do it I have the whole car off the ground on jack stands, so maybe I am getting a little more clearance under the frame on the rear as the front is up too. I do not lie under the car while I am doing this as I am always afraid I'll pull the car off the jack stands...
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Mar 4, 2005 | 07:41 PM
dss's Avatar
dss
I had the same problem with the rear bolts as you have, the loctite hold them on even with liquid wrench, I have an air gun so I ended up using it as my torque wrench was also to long and I didn't want to get up under the car. The liquid wrench works good getting the rear rotor off just put them on each lug nut bolt and wait about 10 min and then us a big hammer. good luck
Old Mar 5, 2005 | 02:49 AM
sprinter's Avatar
sprinter
If they have Loctite on them, none of these "liquid wrench" product will do anything. Probably the rears dont have Loctite which will let the stuff lubricate the thread. One of the few things that can dissolve Loctite is Methylene Chloride (paint stripper) but this wont do much either because it cannot penetrate into the thread.
Also, I would recommend to use Loctite 242 or 243 on the bolt. Loctite 271 and 277 are designed for bolts that you never want to remove again.
The only thing that weakens the threadlocker is heat. The higher the heat, the less retained strength. The adhesive will start to carbonize at around 200-250deg.C (hot). Make sure you apply torque while it is hot.
Ps. I design Loctite adhesives for a living...
