Rear lights out-not bulbs?!!
Old Feb 28, 2005 | 08:28 PM
NewCents's Avatar
NewCents
Default Tail lights out-not bulbs?!!
My driver's side taillights are out (the 2 on the back). I took out the bulbs and tested them and they are fine. So whatever is sending the signal to the lights is out. Any suggestions?
Thanks for any help
Old Feb 28, 2005 | 10:03 PM
Special K's Avatar
Special K
Thanks for any help
Use a probe light or volt meter and see if the current is getting back there. Could be wiring.
Bob
Old Mar 1, 2005 | 04:22 AM
98VertPDX's Avatar
98VertPDX
I had same thing not long ago and it ended being the "flasher switch" (I can't recall the exact name.) It is a little difficult to replace... Hope this helps,
Luis
Old Mar 1, 2005 | 09:17 AM
compton's Avatar
compton
my guess is if you have running lights and turn signal lights on that side it's the turn signal switch itself.
Old Mar 1, 2005 | 11:41 AM
NewCents's Avatar
NewCents
Okkkay
Just got back from the dealership. Picked up a $45 hazard switch, installed it and is still doesn't work!
Any other ideas?
Thanks for any help
Old Mar 1, 2005 | 11:52 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NEWCENTS
When I get home tonight I will take a look in the shop manual for you and give you a coulpe of troubleshooting tips.
Bill Curlee
Old Mar 1, 2005 | 06:29 PM
NewCents's Avatar
NewCents
Man that would be great!
I've checked the fuses, grounds, cleaned the rear harness (the one by the passenger wheel well), installed the new hazard switch, tested the bulbs. The previous owner installed a new turn signal switch less than 7000 miles ago I believe. He was having problems with the headlights and the turn signal assembly (according to the dealership).
I have no idea what's going on! I've searched the forum for everything related to this and diagnosted everything said!!!!??
grrr....
Old Mar 2, 2005 | 07:37 AM
compton's Avatar
compton
still didnt answer my questions.
do you get any lights at all on that side? brake, hazzard, turn signal, running?
try this,
http://bdubbownzyou.com/1.pdf
http://bdubbownzyou.com/2.pdf
Old Mar 3, 2005 | 01:03 PM
NewCents's Avatar
NewCents
No both driver's side taillights are completely out. No turn signal, no hazards, no brakelights, nothing. It is as if both bulbs went out but that is not the case.
Thank you
Old Mar 3, 2005 | 01:34 PM
Blue Lightening's Avatar
Blue Lightening
Thank you
My guess is that you have a bad ground.
Norm
Old Mar 5, 2005 | 05:55 AM
NewCents's Avatar
NewCents
ttt
Old Mar 5, 2005 | 12:33 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Examine and clean grounds G-401 and 402. They are both on the frame behind the rear tires. If you have a newer C5 you may not have anything connected to G-402. There is a splice pack (SP-400) that ALL of the grounds from each light set tie together in but I have never seen what a splice pack looks like. If cleaning the ground G-104 failes to correct the issue, check the harmess and find that splice pack.
Here is a picture of G-104.
You will have a stud in that location. Mine broke off during removal of the nut and I had to replace it with a self tapping sheet metal screw.
BC
Old Mar 5, 2005 | 12:38 PM
Special K's Avatar
Special K
BC
I suggested he use a probe or volt meter to check current. That would tell him if it was a bad ground. Guess he didn't want to try the easy stuff first.
Bob
Old Mar 5, 2005 | 01:33 PM
drwilson's Avatar
drwilson
Cruising
Default Blacliestvette
Thanks for any help
Had similar problem with my 98 vette. replaced turn signal assembly, problem solved.
Old Mar 7, 2005 | 05:10 PM
NewCents's Avatar
NewCents
I checked everything with a probe and a good ground and the positive wires are not sending a signal. I can't believe it would be related to the turn signal assembly as this was just replaced a few thousand miles ago.
What fuses would be related to what's going on? I opened up both fuse boxes (below the hood and passenger) and pulled all the ones I could tell that were related to this and couldn't find anything.
Please help!
Old Mar 7, 2005 | 08:40 PM
larry5868's Avatar
larry5868
Cruising
same with my 2000
Old Mar 7, 2005 | 09:45 PM
highpressuremax's Avatar
highpressuremax
multi-function switch
Old Mar 7, 2005 | 10:11 PM
Special K's Avatar
Special K
Please help!
If you're saying it's just the taillights, maybe it's time to run a new wire from the other side.
Bob
To Rear lights out-not bulbs?!!
