removing front lowering bolts?
Old Mar 2, 2005 | 05:33 PM
DEALER1's Avatar
DEALER1
I did mine today.
It looks sooooooooooooo much better.
Ill post pics tomorrow.
Old Mar 2, 2005 | 05:55 PM
jjjflex's Avatar
jjjflex
Can someone post a pic by pic, on the steps to remove the front lowering bolt? Thanks
Old Mar 2, 2005 | 11:02 PM
raidersfan's Avatar
raidersfan
From: Spread The Virus!!!!!!! Opie and Anthony XM Satellite Radio
Sorry, I don't have my bolts I had to cut them.
Old Mar 2, 2005 | 11:07 PM
lovemyc5vette's Avatar
lovemyc5vette
Banned for being a waste of skin.
I have seen Raiders car in person, it is awesome. It is as low as I think a Vette can be, it is actually lower than the picture (especialy with that gorilla in it!) Just kidding man but you are a freakin monster, his arms are like the size of waist! His front tires are tucked in the wheel well when I saw it.
Hey Raider what exhaust is on it, it is LOUD!
BTW I am the skinny kid that was talking to you with the Rangers hat on at the mall last week.
Old Mar 2, 2005 | 11:11 PM
DEALER1's Avatar
DEALER1
Here you go.
https://www.corvetteforum.com/techti...D=90&TopicID=1
Old Mar 3, 2005 | 12:18 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Im going to have to find the picture but someone has his front lowered 25". Its a white Coupe.............
Old Mar 3, 2005 | 12:24 AM
Dirty Howie's Avatar
Dirty Howie
Originally Posted by DEALER1
I did mine today.
Glad you had the *****....lets see the pics. And a ground to fender well measurement!!
Did you put rubber in and if so how thick?
I was looking over those pics of the bushing cutting (which I had done) and whats left doesn't look very thick. I would think 1/4 rubber would be same as what left on the bushing.
Wish I had watched them cut my bushing...still think they only removed 1/3 instead of 2/3 of it.
Old Mar 3, 2005 | 12:32 AM
DEALER1's Avatar
DEALER1
Ill get the pics tomorrow.
I have the 19-20 wheel combo.
The tires now are about 1/2 inch taller than stock runflats.
Now my ground to fender height is 25 3/4.
I didnt use any rubber spacer. I only used lithium grease.
Old Mar 3, 2005 | 11:46 AM
gmosley's Avatar
gmosley
Default ride
so hows the ride with no front bolts
can it even be aligned
Old Mar 3, 2005 | 02:16 PM
DEALER1's Avatar
DEALER1
[/quote]
Old Mar 3, 2005 | 02:17 PM
DEALER1's Avatar
DEALER1
It really doesnt ride much different.
I hope it can be aligned.
Old Mar 3, 2005 | 02:20 PM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
Much Better!!!
It should settle a little more. I got down to 25.5" with the bolts removed.
Old Mar 3, 2005 | 02:23 PM
  #33
DEALER1's Avatar
DEALER1
Thanx
Old Mar 3, 2005 | 04:23 PM
  #34
Dirty Howie
Looks GREAT!!
Why no rubber??
Why wouldn't you be able to get an alignment??
Old Mar 3, 2005 | 04:49 PM
  #35
see5's Avatar
see5
Not to be a jerk about this but:
If you lower the front the car excessively you have very little suspension travel cause it bottoms on the spring bumpers. So you cut the bumpers and it has virtrually no suspension travel and will handle terribly on anything but a smooth road, but you take the bolts out, so now it shatters the shock bumpers cause that is next in line. Once that is finshed the shocks have no travel and a bad bump or brake spike should pop the shocks out of the lower control arms or fracture the wheel well at which point you are as low as you can go...
Old Mar 3, 2005 | 05:22 PM
  #36
99blackFRC's Avatar
99blackFRC
If you lower the car excessively you have very little suspension travel cause it bottoms on the spring bumpers. So you cut the bumpers and it has virtrually no suspension travel and will handle terrible on anything but a smooth road, but you take the bolts out, so now it shatters the shock bumpers cause that is next in line. Once that is finshed the shocks have no travel and a bad bump or brake spike should pop the shocks out of the lower control arms or fracture the wheel well at which point you are as low as you can go...
eh?
Two years with no bolts, nothing in between spring and control arm, no shock damage, no spring damage, no adverse effects noted to date...
and to note, I noticed a huge difference in handling over stock, but that wasn't my reasoning for doing it - it was purely for the look. I'd never go back to 4x4 appearance after the amount of compliments I get.
Old Mar 3, 2005 | 05:28 PM
  #37
raidersfan's Avatar
raidersfan
Originally Posted by 99blackFRC
eh?
To removing front lowering bolts?
Old Mar 3, 2005 | 07:14 PM
  #38
99Z51R's Avatar
99Z51R
Cruise-In III Veteran
St. Jude Contributor '04
Originally Posted by raidersfan
Yep, three years here, been to Kentucky twice and drive it in Iowa, so you know I don't see any smooth rodes
Old Mar 3, 2005 | 08:06 PM
  #39
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
This seems to be one of those things that...
The only people advising against it, have never done it.
The people who have done it don't seem to have any complaints.
Many people told me 2 years ago my ride quality would suck if I cut the front bushings off.
Well. it's been 20,000 miles now w/o the bushings. Car still rides smooth as silk.
Experience vs theory...I know which one I trust more.
Old Mar 3, 2005 | 08:25 PM
  #40
toplessvettetherapy's Avatar
toplessvettetherapy
Default Slammed!!!!!!
I just wanted to compliment 99Z51R on his ride, as far as I am concerned it is the sweetest looking car on the forum. Now that I am through flattering him , I took my front bolts out and installed the longer bolts in the rear and the car really looks awesome.It is about 25 3/4 "infront and 26 3/4 in the rear.With the 20'' wheels on the rear I may end up having to raise it up just a hair , because I only have about 1'' of clearance between tire and finder. Thanks to the forum on great "how to's".
