removing front lowering bolts?
Old Feb 28, 2005 | 10:18 PM
DEALER1's Avatar
DEALER1
Default removing front lowering bolts?
I keep hearing people say, in order to get the maximum drop you have to remove the front bolts. Also you need to put a piece of rubber between the spring and aframe.
my question is- What kind of rubber?? from what?? what size?
Old Feb 28, 2005 | 10:24 PM
97C5ENVY's Avatar
97C5ENVY
Any piece of rubber or silicone will work. The main thing here is to help prevent the spring from rubbing on the lower control arm....which can cause squeaks, and over time rub grooves in the lower control arm. I used a piece of a rubber floor mat myself.
Old Feb 28, 2005 | 10:30 PM
DEALER1's Avatar
DEALER1
Thanks, thats what i needed to know.
Old Feb 28, 2005 | 11:57 PM
STA-BLK's Avatar
STA-BLK
Has anyone gotten the bolts out without removing the upper control arm,without cutting it in the process.
Old Mar 1, 2005 | 12:21 AM
DEALER1's Avatar
DEALER1
Old Mar 1, 2005 | 12:29 AM
stngh8r's Avatar
stngh8r
if anyone has some front bolts they arent using, i would be interested in getting them from you. Thanks
Old Mar 1, 2005 | 12:37 AM
Dirty Howie's Avatar
Dirty Howie
By the looks of your car you are already pretty damn low!!
Old Mar 1, 2005 | 12:41 AM
Dirty Howie
How thick was the rubber you used?
What is your ground to fender height?
I have same sized front wheels as you and new Z06 springs. Bushings are cut and I am at 26.5 inches. Would like another .5 inch....
Old Mar 1, 2005 | 01:18 AM
lowdowndirty's Avatar
lowdowndirty
I got the bolts out and back in without disconnecting the control arm. I had a buddy pry the spring up from the control arm while I fished the bolt out. Not the safest method but it worked.
Old Mar 1, 2005 | 02:58 AM
viper punisher's Avatar
viper punisher
I just did the "front's" today, and I must say it is super easy!
I had the lower ball joint, swaybar, and tierod disconnected and the bolt out in 15 minutes.
Here are some pics from the job today.
Old Mar 1, 2005 | 07:57 AM
see5's Avatar
see5
Stand by for smashed shock bumpers. That is what the suspension is now bottoming out on.
Old Mar 1, 2005 | 06:27 PM
Dirty Howie
Looks like those bushings were already cut...right? And now you took them out. Did you put some rubber in there? And how much lower did it go from the cut bushing height?
Old Mar 1, 2005 | 09:01 PM
stngh8r's Avatar
stngh8r
Hey Viper Punisher (or anyone else for that matter) You wouldnt by any chance be willing to get rid of those bolts would you? I need some bad, but i would be happy to at least get some precise measurments so that i may be able to get a bolt that will work from a hardware store or something.
THanks
eric <><
Old Mar 1, 2005 | 09:10 PM
RAFTRACER's Avatar
RAFTRACER
Old Mar 1, 2005 | 09:25 PM
99Z51R's Avatar
99Z51R
Cruise-In III Veteran
St. Jude Contributor '04
I've had mine out for three years, I also cut the shock bumber in half, it doesn't bottom at all. Ran stock shocks for about a year then went Bilstiens, not a huge differance. I also just rubbed a little synthetic grease on the A-arm where the spring now rides, no squeeks and no wear.
Old Mar 1, 2005 | 11:53 PM
Izover4u's Avatar
Izover4u
I have my front bolts removed and is not as low as your car (sig pic)... What did cutting the bumper in half do?
Old Mar 2, 2005 | 12:20 AM
Dirty Howie
I'm sorry......what and where is the shock bumper?
So you don't have any rubber, only grease between the Aarm and spring? Can't this damage the spring?
To removing front lowering bolts?
Old Mar 2, 2005 | 01:28 AM
rarfinacial's Avatar
rarfinacial
where is the shock bumper? does cutting them in 1/2 give your shocks more movement? is the ride smoother?
Old Mar 2, 2005 | 04:48 PM
99Z51R's Avatar
99Z51R
If you take the shock cap off theres a snowman looking piece that I just cut in half, so it has a little more travel, did the same thing to the bilstiens. As far as damage, I have had it apart many times as I put the cut bolts in when I run my drag package and there is very minimal wear on the A-arm, a small piece of plastic or rubber I'm sure wouldn't hurt. I've lowered many C4's and the spring rides on the A-arm from the factory.
Izover4u- I think the extra weight of the magnuson is why my car sits a little lower than most.
Eric
Old Mar 2, 2005 | 05:21 PM
raidersfan's Avatar
raidersfan
From: Spread The Virus!!!!!!! Opie and Anthony XM Satellite Radio
I don't think anyones front sits lower than mine. 25 1/4".
