Install DTE brace help
Old Mar 1, 2005 | 10:19 PM
killaz's Avatar
killaz
Default Install DTE brace help
How do you install this? I was thinking of getting one. Can it be done with the car intact or do you need to tare the car apart.
Adam
Old Mar 1, 2005 | 11:21 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
DTE will send you a set of instructions with it. You can do it with the car together. I think it will be a little tougher because of confined spece but it can be done.
Old Mar 1, 2005 | 11:22 PM
Cajundude's Avatar
Cajundude
I did mine while changing gears, you can see that here.
Old Mar 2, 2005 | 12:32 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
I recently asked this question.
For automatic cars, I guess the subframe will have to be dropped to get it in.
For manual cars, you WILL have to remove or move the exhaust out of the way, but other than that it's supposed to be pretty straightforward. 2-3 hours is the time estimate I was given.
Old Mar 2, 2005 | 07:13 AM
supercoupe01's Avatar
supercoupe01
Installed mine this weekend (MN6) on a lift. Took about four hours. Directions are straight forward and the only difficult part is getting to the top bolts on the passenger side, the rest wasn't that bad.
Old Mar 2, 2005 | 07:55 AM
Cajundude's Avatar
Cajundude
With your car together,
1. Count the number of threads on the ride height bolts and write it down.
2. Release spring tension buy using jack as support under one side of spring at a time and completely remove the bolt. Gently lower until the spring tension has been removed. Do other side.
3. Remove two upper and two lower anti-sway bar mounting straps fastners on each side of crossmember and lower the anti-sway bar out of the way by swinging it down.
4. Remove the cat-back.
5. Put jack under crossmember and loosen the four crossmember bolts and lower the crossmember down about an inch. This should give you the clearance you need.
To Install DTE brace help
