Code help, please!
Old Mar 4, 2005 | 02:31 PM
Rag-Top Rick's Avatar
Rag-Top Rick
Default Code help, please!
Greetings All,
I pulled up this history code the other day and couldn`t find it on the code list I printed out some time ago.
The code is: P0748
Thank you in advance for your help.
Cheers, Rick (R.P.)
Old Mar 4, 2005 | 02:41 PM
jmzvet's Avatar
jmzvet
P0748 Pressure Control Solenoid Circuit Electrical
Old Mar 4, 2005 | 02:50 PM
Rag-Top Rick
Hey Jim!
I know you have a manual trans but do you have any idea if this is related to an auto trans? You may or may not recall my mentioning that my tranny was shifting funny when we pulled over to the side of the road to allow the Boss 302 to gas up last Sat.
Jim..... anyone?
Thank you advance for the input.
Cheers, Rick (R.P.)
Old Mar 4, 2005 | 06:27 PM
jmzvet's Avatar
jmzvet
I'll ask around and get some info.
Old Mar 4, 2005 | 09:36 PM
jmzvet's Avatar
jmzvet
The best I could find out is that it's possibly a solenoid or maybe a
fuse/electrical problem.
Old Mar 5, 2005 | 06:09 PM
jmzvet's Avatar
jmzvet
Here's some info I dug up.
DTC P0748 Pressure Control Solenoid Circuit Electrical 5.7L
Circuit Description
The pressure control (PC) solenoid valve is an electronic device that regulates transmission line pressure based on the current flow through its coil winding. The magnetic field produced by the coil moves the solenoid's internal valve which varies pressure to the pressure regulator valve. The powertrain control module (PCM) controls the PC solenoid valve by applying a varying amount of amperage to the solenoid. The applied amperage can vary from 0.1 to 1.1 amps. Low amperage (0.1 amp) indicates high line pressure. High amperage (1.1 amps) indicates low line pressure. The duty cycle of the PC solenoid valve is expressed as a percentage of energized ON time. Zero percent indicates zero ON time (non-energized) or no current flow. Approximately 60% at idle indicates maximum ON time (energized) or high current flow. The PCM determines the appropriate line pressure for a given load by comparing the throttle position (TP) voltage, the engine speed and other inputs.
When the PCM detects a continuous open or short in the PC solenoid valve circuit, then DTC P0748 sets. DTC P0748 is a type C DTC.
Conditions for Running the DTC
The system voltage is 8-18 volts.
The engine is running.
Conditions for Setting the DTC
The PC solenoid valve duty cycle reaches its high limit (approximately 95%) or low limit (approximately 0%).
Action Taken When the DTC Sets
The PCM does not illuminate the malfunction indicator lamp (MIL).
The PC solenoid valve is OFF.
The PCM freezes shift adapts from being updated.
The PCM records the operating conditions when the Conditions for Setting the DTC are met. The PCM stores this information as Failure Records.
The PCM stores DTC P0748 in PCM history.
Conditions for Clearing the DTC
A scan tool can clear the DTC.
The PCM clears the DTC from PCM history if the vehicle completes 40 warm-up cycles without a non-emission-related diagnostic fault occurring.
The PCM cancels the DTC default actions when the fault no longer exists and/or the ignition switch is OFF long enough in order to power down the PCM.
Diagnostic Aids
Inspect the connectors at the PCM, the PC solenoid and all other circuit connecting points for an intermittent condition. Refer to Testing for Intermittent and Poor Connections in Wiring Systems.
Inspect the circuit wiring for an intermittent condition. Refer to Testing for Electrical Intermittents in Wiring Systems.
DTC P0748 may set under low voltage conditions caused by high electrical system demands.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
This step tests the ability of the PCM to command the PC solenoid valve.
This step tests the PC solenoid valve and automatic transmission (AT) wiring harness assembly for incorrect resistance.
DTC P0748 PC Solenoid Circuit Electrical (5.7L)
Step
Action
Value(s)
Yes
No
1
Did you perform the Powertrain Diagnostic System Check?
Go to Step 2
Go to A Powertrain On Board Diagnostic (OBD) System Check in Engine Controls
2
Install a Scan Tool .
Turn ON the ignition, with the engine OFF.
Important
Before clearing the DTC, use the Scan Tool in order to record the Failure Records. Using the Clear Info function erases the Failure Records from the PCM.
Record the DTC Failure Records.
Clear the DTC.
Start the engine.
Use the Scan Tool in order to command 0.1 amp through 1.0 amp while observing PC Sol. Ref. Current and PC Sol. Actual Current.
Is the PC Sol. Actual Current always within the specified value of the PC Sol. Ref. Current?
0.16 amp
Go to Diagnostic Aids
Go to Step 3
3
Turn OFF the ignition.
Disconnect the AT inline 20-way connector.
Install the J 44152 jumper harness (20 pins) on the transmission side of the AT inline 20-way connector.
Using the J 39200 digital multimeter (DMM) and the J 35616-A connector test adapter kit, measure the resistance between terminals C and D of the J 44152 . Refer to Automatic Transmission Inline Harness Connector End View .
Does the resistance measure within the specified range?
3-7 ohms
Go to Step 5
Go to Step 4
4
Does the resistance measure greater than the specified value?
7 ohms
Go to Step 9
Go to Step 10
5
Measure the resistance from terminal C of the J 44152 to the transmission case. Refer to Automatic Transmission Inline Harness Connector End View . Does the resistance measure greater than the specified value?
250 K ohms
Go to Step 6
Go to Step 11
6
Disconnect the J 44152 from the transmission side of the AT inline 20-way connector.
Reconnect the transmission AT inline 20-way connector.
Disconnect the PCM connector C2.
Measure the resistance between PCM connector terminal C2-6 and terminal C2-8.
3-7 ohms
Go to Step 8
Go to Step 7
7
7 ohms
Go to Step 12
Go to Step 13
8
Using the J 39200 DMM and the J 35616-A , measure the resistance from PCM connector terminal C2-6 to ground. Does the resistance measure greater than the specified value?
250 K ohms
Go to Step 17
Go to Step 14
9
Test the controlled power feed circuit (CKT 1228) and the controlled ground circuit (CKT 1229) of the PC solenoid for an open between the AT inline 20-way connector and the PC solenoid. Refer to Circuit Testing in Wiring Systems. Did you find an open condition?
Go to Step 16
Go to Step 15
10
Test the controlled power feed circuit (CKT 1228) and the controlled ground circuit (CKT 1229) of the PC solenoid for a shorted together condition between the AT inline 20-way connector and the PC solenoid. Refer to Circuit Testing in Wiring Systems. Did you find a shorted together condition?
Go to Step 16
Go to Step 15
11
Test the controlled power feed circuit (CKT 1228) and the controlled ground circuit (CKT 1229) of the PC solenoid for a short to ground between the AT inline 20-way connector and the PC solenoid. Refer to Circuit Testing in Wiring Systems. Did you find a short to ground condition?
Go to Step 16
Go to Step 15
12
Test the controlled power feed circuit (CKT 1228) and the controlled ground circuit (CKT 1229) of the PC solenoid for an open between the PCM connector C2 and the AT inline 20-way connector. Refer to Circuit Testing and Wiring Repairs in Wiring Systems. Did you find and correct the condition?
Go to Step 18
13
Test the controlled power feed circuit (CKT 1228) and the controlled ground circuit (CKT 1229) of the PC solenoid for a shorted together condition between the PCM connector C2 and the AT inline 20-way connector. Refer to Circuit Testing and Wiring Repairs in Wiring Systems. Did you find and correct the condition?
Go to Step 18
14
Test the controlled power feed circuit (CKT 1228) and the controlled ground circuit (CKT 1229) of the PC solenoid for a short to ground between the PCM connector C2 and the AT inline 20-way connector. Refer to Circuit Testing and Wiring Repairs in Wiring Systems. Did you find and correct the condition?
Go to Step 18
15
Replace the PC solenoid valve. Refer to Control and Shift Solenoids Replacement . Did you complete the replacement?
Go to Step 18
16
Replace the AT wiring harness assembly. Refer to Torque Converter Clutch Pulse Width Modulation (TCC PWM) Solenoid, TCC Solenoid, and Wiring Harness . Did you complete the replacement?
Go to Step 18
17
Replace the PCM. Refer to PCM Replacement/Programming in Engine Controls. Did you complete the replacement?
Go to Step 18
18
Perform the following procedure in order to verify the repair:
Select DTC.
Select Clear Info.
Start the engine and ensure that the following condition is met: The difference between the Scan Tool PC Sol. Actual Current and the PC Sol. Ref. Current is less than 0.16 amp.
Select Specific DTC.
Enter DTC P0748.
Has the test run and passed?
System OK
Go to Step 1
To Code help, please!
