Octane Booster WARNING!!!
Old Mar 4, 2005 | 08:28 PM
TKTFNDR's Avatar
TKTFNDR
4th Gear
Default Octane Booster WARNING!!!
I just got my C5 back after a week long ordeal. Monday my check engine light came on. I took it to the dealer, they said they reset the code and it should be fine. After I drove a block the check engine light came on again. So I took it back. Test after test and they finally asked if I had been using Octane Boost. I told them yes (STP Octane Boost) with 92 Octane gas. Come to find out that after a month of using this mix. The Knock and Ping sensors in the lower engine had to be replaced. This could have been a costly lesson learned had I not had the extended warranty. I just wanted to pass this on if anyone was thinking of using Octane Boost. I agree, it's a Vette... It probably didn't need it anyway.
Old Mar 4, 2005 | 08:44 PM
90 droptop's Avatar
90 droptop
I think the dealership is giving you a line
Old Mar 4, 2005 | 08:46 PM
ArKay99's Avatar
ArKay99
The only knock sensors I know about are the 2 mounted in the valley cover on a C5. How could octane boost damage a sealed piezo electric transducer? And they are in the top of the engine. Unless you were using leaded octane boost and you fried your cats, but they aren't sensors. Is STP octane boost leaded or designed not to be used with cats? If you want some octane boost I would recommend Torco.
Old Mar 4, 2005 | 08:56 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
maybe it took out the O2 sensors?
Old Mar 4, 2005 | 09:08 PM
Wah's Avatar
Wah
O2 sensors are the most logical explanation. Most octane boosters leave deposit in the combustion chambers. I have seen pictures of a cylinder head which covered in dark orange deposit after the engine had used octane boosters.
If they can leave deposit inside the combustion chamber, I would think that it's possible to contaminate the O2 sensors, eventually. Cats maybe in danger too and if it's so, the downstream O2 sensors may become victims.
Now what I'm wondering is, if the deposit will act like carbon deposit where tiny peaks will get hot enough and initiate auto-ignition which in turn necessitating more octane booster to keep the engine from detonating. I wouldn't be surprised if that was the ploy. Sell more octane boosters. It's like trying to get someone to get addicted to drugs. Except it's the engine gets "addicted" to the octane booster.
Oh well. That's just a theory.
Old Mar 4, 2005 | 09:11 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
but the O2 sensors aren't even on the motor so I still call on the stealership
Old Mar 4, 2005 | 10:07 PM
shurite44's Avatar
shurite44
Go into history and post the code, I bet it is for the cats.
Old Mar 5, 2005 | 09:56 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Most Octane Boosters, including AMSOILs contain lead, which will eat up the 02 sensors in a big hurry. I suspect this is what they are talking about, not the knock sensors.
I believe there is one Octane Boost on the market that doesn't have lead. I've read about it on this forum. Starts with a T but I'm drawing a blank. Sorry.
I believe these are the part numbers for a Z06, not 100% sure if they are the same for a C5. You need two of each.
Oxygen Sensor Front 25312184 ($37 from GM Part Direct)
Oxygen Sensor Rear 25317697 ($85 from GM Part Direct)
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Mar 5, 2005 | 11:28 AM
mdhmi's Avatar
mdhmi
I've had very good results with unleaded Torco.
Mark
Old Mar 5, 2005 | 11:39 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I have used Torco and 100 unleaded race gas... Once I had a O2 sensor go out... so I replaced both of the fronts (my 99 has 4 sensors)
VR
Old Mar 5, 2005 | 11:58 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If they really said that octane booster killed your KNOCK sensors, they are full of crap!!! There is NO WAY that the knock sensore can be exposed to the exhaust or even the combustion chamber.
BC
Old Mar 5, 2005 | 12:21 PM
BlueDragon's Avatar
BlueDragon
I agree with all of the above Had octane boost crap up a set of plugs and stopped using it. As for the dealership go get a big flag and wave it outside the service department. They are feeding you a line of crap . yes the O2 sensors, are most likely the problem. KR sensors? Not a chance in hell!
Old Mar 5, 2005 | 02:13 PM
C66 Racing's Avatar
C66 Racing
VR
Torco thanks. That is what I've read about being okay for the 02 sensors.
To Octane Booster WARNING!!!
