push starting a MN6 C5
Old Mar 5, 2005 | 10:32 AM
Lancer033's Avatar
Lancer033
Default push starting a MN6 C5
just got finished watching an old episode of American Hotrod and the had to push start one of their car. I've seen it done on older cars, but if you were in a pinch, could you do it to a C5, or would the computer not like it.
Old Mar 5, 2005 | 10:40 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
it can be done...
Old Mar 5, 2005 | 10:41 AM
ALLEGRO's Avatar
ALLEGRO
It will work. Could cause a stumble in the computer but should not.
The starter interupt is just for starting the car in gear.
Old Mar 5, 2005 | 10:46 AM
rockgt302's Avatar
rockgt302
St. Jude Donor '05
Ive done it.
Old Mar 5, 2005 | 10:50 AM
ragtopws6's Avatar
ragtopws6
Me too.
Old Mar 5, 2005 | 10:53 AM
C5 ChemE's Avatar
C5 ChemE
Excuse my inexperience, but how is this done?
Old Mar 5, 2005 | 11:04 AM
Lancer033's Avatar
Lancer033
either push the car or roll it down a hill in 1st gear with the clutch in, when you get some speed, let the clutch out. When the clutch catches either the wheels have to stop or the engine has to turn, and with 3000lbs behind them the wheels win and the engine will turn over the same was the starter would do it.
it's a good trick if you get stuck with a bad starter or battery. That's what happened on the show and got me thinking about it. Hopefully I won't every have to do it.
Old Mar 5, 2005 | 11:07 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
Put key in run position, Push the car enough to get good momentum, and i mean good. jump back in, press clutch in, put it in 1st gear, then pop the clutch. The engine will start and you will be in gear already so put it in neutral.
If your lucky enough to be stuck downhill, its alot easier.
Old Mar 5, 2005 | 03:23 PM
6 speed Sid's Avatar
6 speed Sid
Never done it on a C-5, but plenty of times on other vehicles. Other gears than 1st will also work. In the old days when cars and trucks had good bumpers, it was common to give your buddy a push to get the other vehicle moving, then back off while he popped the clutch.
Old Mar 5, 2005 | 03:45 PM
Jim2003's Avatar
Jim2003
I've found out over the years that using 2nd gear is much better than 1st gear. Sometimes you may not have enough forward speed for 1st to turn the engine over, whereas 2nd gear will work better.
Old Mar 5, 2005 | 03:59 PM
99 The Hard Way's Avatar
99 The Hard Way
It will help to turn off the traction control, it won't like it if you leave it on. I've push started mine also. Scott
Old Mar 5, 2005 | 04:21 PM
C5inWV's Avatar
C5inWV
Old Mar 5, 2005 | 04:24 PM
EHS's Avatar
EHS
You're kidding, right?
Old Mar 5, 2005 | 04:41 PM
Ebein's Avatar
Ebein
Never had to Pop-Start the Vette, but Ive always done my other
cars in second as well
Old Mar 5, 2005 | 05:45 PM
Monster231's Avatar
Monster231
Ive done it too, Not my favorite thing to doo, but when you in a jam...
Old Mar 5, 2005 | 06:40 PM
corvettefreak16's Avatar
corvettefreak16
I've done it but it wasnt very fun.
Old Mar 5, 2005 | 07:07 PM
ErnieN85's Avatar
ErnieN85
I found out something not so nice about push starting. I won't work if the battery is real dead. The reason is there isn't enough power to excite the alternator or run the fuel pump........soon as the fuel pressure in the linne drops it quits. That is if the battery is under about 8 volts or so. in the old days (with a generator) there was enough residual magnetism that a generator would put out power and it would work, now that we have alternators it doesn't
To push starting a MN6 C5
Old Mar 5, 2005 | 07:50 PM
Sixants's Avatar
Sixants
Unfortunately I've done this 4-5 times in the last three days while waiting for a starter. have a 98. Turn the key to run, put in nuetral and push like hell. When you've got the speed, jump in and and put it in 2nd. Works great in a pinch. Just don't stall at a red light!!
Old Mar 5, 2005 | 08:03 PM
raidersfan's Avatar
raidersfan
From: Spread The Virus!!!!!!! Opie and Anthony XM Satellite Radio
Old Mar 5, 2005 | 08:15 PM
LoneStarFRC's Avatar
LoneStarFRC
Better mechanical advantage than first. Just have to get the speed up good though.
