Drivers side power lock
Old Mar 6, 2005 | 05:57 PM
ericdwong's Avatar
ericdwong
Default Drivers side power lock
...anyone replace the power lock solenoid? I think I need to replace mine, its gotten to the point if I hit the automatic locks, it wont lock until maybe 1 in every 4 or 5 tries. Real annoying and probably pretty unsafe with the doors unlocked...Part numbers? Instructions?? Tips?
Old Mar 7, 2005 | 01:45 AM
ericdwong's Avatar
ericdwong
Ttt
Old Mar 7, 2005 | 08:26 AM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Power Lock
________________________________________ ____________________
[eRiCdWoNg]...anyone replace the power lock solenoid? I think I need to replace mine, its gotten to the point if I hit the automatic locks, it wont lock until maybe 1 in every 4 or 5 tries. Real annoying and probably pretty unsafe with the doors unlocked...Part numbers? Instructions?? Tips?
My drivers door will not lock with the inside button or with the remote. If I manually lock it and walk away, the remote will work and open the door. I'll live with it for now. Question....is it the solenoid or is it the module, or are the both the same animal?
Old Mar 7, 2005 | 09:17 AM
stockC5's Avatar
stockC5
It's the module located inside the drivers door. The exact same thing happened to my 2002 vert. The dealership replaced it under warranty. Hope this helps
Old Mar 7, 2005 | 10:25 AM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
Try a fresh battery first.
Old Mar 7, 2005 | 10:48 AM
vetdude's Avatar
vetdude
When the same thing happened to me on my '99 it turned out to be the BCM (Body Control Module) located behind the driver's side headrest under the lip of the hatch opening- like $300 for a new module.
Old Mar 7, 2005 | 10:57 AM
viper punisher's Avatar
viper punisher
Similar thing for me too.. The drivers door locks but wont unlock all the time. I get a LDCM and BCM code once in a while also.
To Drivers side power lock
