location pcm
Old Mar 6, 2005 | 06:10 PM
Vettegetsmwet99's Avatar
Vettegetsmwet99
Default location pcm
where is the pcm located and is it hard to get to
Old Mar 6, 2005 | 06:39 PM
69's Avatar
69
Cruise-In VI Veteran
Remove the right front tire, remove the acess panel on the aft side of the wheel well, it's easy to get to.
Old Mar 6, 2005 | 06:42 PM
Vettegetsmwet99
thank you
Old Mar 6, 2005 | 06:43 PM
Patches's Avatar
Patches
Throttle control module has to come off first and then the PCM.
Old Mar 6, 2005 | 08:37 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Great Patches
Great Drawing Patches.......................
Old Mar 6, 2005 | 08:40 PM
Special K's Avatar
Special K
After removing the passenger side front tire and the access panel inside the wheel well the TAC & PCM are exposed. The only difficult part of the whole deal are the back mounting screws. You have to be a contortionist to get to these. Remove the TAC module (2 screws) and then remove the two connectors from the TAC. Once this is out of the way, remove the two connectors from the PCM. These are self extracting connectors that will back out when you turn the mounting screw. Next, loosen the rear mounting screw in the PCM bracket, but don't remove it. Remove the two front mounting screws from the bracket. The PCM will now slide out towards curbside. Reverse this procedure to install but don't tighten the rear PCM mounting screw and do not install the rear mounting screw for the TAC. This will make the next removal much easier. I just used a nylon tie wrap to secure the back of these modules. It is not necessary to disconnect the battery or any fuses to perform this change.
Bob
Old Mar 6, 2005 | 10:02 PM
Vettegetsmwet99
thanks for the help, i just got out the black box and i did not know there was a screw in the back of it where i couldnt see and it broke, oh well the two screws in the front should hold it fine.
Old Mar 6, 2005 | 10:28 PM
Special K's Avatar
Special K
Read what I posted. Tie wraps
Bob
Old Mar 6, 2005 | 10:32 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Using Bob's description, I can get my PCM out and back in without disconnecting or removing the TAC. I just leave it attached to the bracket that holds in the PCM.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Mar 7, 2005 | 08:56 AM
Special K's Avatar
Special K
Always more than one way to skin a cat. I wonder where that expression came from? Maybe I don't want to know.
Bob
Old Mar 7, 2005 | 05:16 PM
Vettegetsmwet99
thanks for the help guys
To location pcm
