C4 vs C5 Maintenance and Repair
Old Mar 6, 2005 | 07:44 PM
LTxDave's Avatar
LTxDave
Default C4 vs C5 Maintenance and Repair
OK...this is not the typical C4 vs C5 post, so lets keep the "this is a superior design" "that is better looking" to a minimum please.
What I'm interested in knowing is how the C5 compares to the C4 in the ease of maintenance category that I've never heard discussed. I'm working on a 95 right not and pulling the engine and lets just say things are a bit cramped. The wiring harness is run in odd places that seem that would lead to shorts, etc. and connectors are tucked up into tiny crevices that my small hands can't easily access. Has any of this been improved on the C5? How is engine removal, spark plug access, transmission removal, etc? I appreciate any responses especially from those of you who do your own maintenance and modifications. Thanks!
Old Mar 6, 2005 | 08:17 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I had an 85 Coupe and I must say that the C5's are much easier to work on mechanicaly. Electronics on the other hand are A LOT more complicated!!! I think that the C5 factory service manuals are better than C4 manuals.
Replacing a clutch is a snap on a C4! On a C5 "FORGET ABOUT IT!"
Working on a C4 intake system is a ROYAL PAIN!!!! On a C5 it is a piece of CAKE!
Bill
Old Mar 6, 2005 | 09:04 PM
leaftye's Avatar
leaftye
I haven't had a C4, but I think the C5 is very easy to work on, except for the drivetrain from the rear cover back... For most things, I can't imagine it being much simpler. Even clutch changes would be easy if I had the right setup to do it. For an idea of what can go wrong, check the sticky in C5 General.
Old Mar 7, 2005 | 07:55 PM
LTxDave's Avatar
LTxDave
Thanks for the responses guys! Does anyone else have anything to add?
Old Mar 7, 2005 | 08:56 PM
crznZ06's Avatar
crznZ06
I have an '88 coupe and an '04 Z06. I've pulled the entire drivetrain out of the '88, and can't imagine it getting any easier, especially in the engine compartment because of the "full" clamshell hood. I was able to get at any fastener I needed to.
I've only changed the fluids on the Z06, and installed a tunnel plate, but it seems just as straight forward. However, it seems that the Z06 would be more difficult to do engine work on because the front fenders stay in place when you open the hood, and clearance seems to be tighter around the engine. Good luck.
Old Mar 7, 2005 | 10:07 PM
Dark-Knight's Avatar
Dark-Knight
Header install is much easier on C5 compared to C4....
Old Mar 8, 2005 | 01:59 PM
LTxDave's Avatar
LTxDave
Wowser...I'm pulling the engine from my 95 right now and its a real PITA. Easy to get to everything = my 70 LeMans.
Old Mar 8, 2005 | 02:52 PM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
A heck of a lot easier -- I have done headers on both my cars and the C5 was a breeze in comparison
Old Mar 8, 2005 | 02:54 PM
ericdwong's Avatar
ericdwong
I have limited experience on a C4 but this is what I've seen- the C5's engine bay is much less cramped and easy to get to. Of course the C4's entire front clip lifts up vs the more traditional hood/fender config on a c5.
The clutch is *much* more difficult on a C5 vs a C4.
Old Mar 8, 2005 | 03:17 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Bill
I also used to own an '85 and so far, everything that I have done to my C4 in the past has been way easier to do to the C5.
To C4 vs C5 Maintenance and Repair
