Which DIC codes are bad and need attention
Old Mar 6, 2005 | 07:53 PM
greg_nate's Avatar
greg_nate
Default Which DIC codes are bad and need attention
Thanks to this board for showing me how to get the information.
I wrote down the following codes, but without thinking, erased them all before finding which one was responsible for the Check Engine light. Some are self explanatory, but a few I am not sure of. If anyone can provide some clarity, I'd much appreciate it. I don't mind an annoying light, but am worried about any serious damage. I am guessing that it is the P0420 code that is causing the check engine light.
PCM:P0420 HC - Catalyst System Low Efficiency Bank 1
TCS:C1291 H - Open Brake Lamp Sw Contacts During Deccel
TCS:C1292 H - Can't find info on this one ???
IPC : U1040 H - Loss of Communications with TCS
IPC : U1056 H - Loss of Communications with RTD
IPC : U1064 H - Loss of Communications with BCM
IPC : U1160 H - Loss of Communications with LDCM
IPC : U1176 H - Loss of Communications with RFA
Thanks,
greg
Old Mar 6, 2005 | 08:10 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thanks,
greg
Greg
The U codes indicate that your dropping battery voltage below 9.0 volts when your starting the engine. As soon as the starter kicks in it pulls lots of amps out of the battery and the voltage drops low. As the starter starts to spin it draws less current and battery voltage comes back up to above 9 volts and the modules work again. How old is your battery and what condition is it in? If your car sits for a long period of time and is low on charge, the same thing can happen.
TCS:C1292 is Low Brake Pressure During Deceleration.
I recommend charging up the battery, clearing all of the codes and see which ones return. You may want to have your battery tested to see if it has enough reserve capacity to prevent it from dropping low during starting.
Bill
Old Mar 6, 2005 | 11:05 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
PCM codes cause the "check engine" light to illuminate, I wish I could explain this for you but I'm not at home right now so maybe someone else can chime in.
Old Mar 6, 2005 | 11:22 PM
djengr's Avatar
djengr
P0420 TWC System Low Efficiency Bank1. Looking at the service manual it basicaly points to the catalytic converter not oxidzing hydrocarbons, carbon monoxide, and NOx. ( My 96 tahoe has the same code and it turns on the service engine light.) After you reset see if it comes back, if so you may have a bad cat. The manual also suggest you inspect exhaust system for leaks or damage and make sure the ox sensors wiring is not damaged.
Old Mar 7, 2005 | 04:11 PM
greg_nate's Avatar
greg_nate
Thanks! It makes me feel better. When the light came on, I freaked out a little bit cuz it is a new car with only 5k miles, but a few mods that might void the warranty.
This would make sense because: I just had headers and RT cats installed. Sofar, it has not come on again.
Old Mar 7, 2005 | 04:19 PM
Crispyc21's Avatar
Crispyc21
Any code that has to do with emissions will cause the check engine light.
To Which DIC codes are bad and need attention
