Traction...how do you guys..
Old Mar 7, 2005 | 07:18 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Traction...how do you guys..
who are putting some serious power to the wheels do it? I mean damn I am only putting 353 to the ground and its all I can do to keep from spinning the tires from 35 mph if I get into it to hard...I can't imagine how you guys at 500 or more do it...I would be buying tires in bulk
Old Mar 7, 2005 | 07:46 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Learn to drive.
Old Mar 7, 2005 | 10:10 PM
mowton's Avatar
mowton
Sometimes finess wins over brute force
Old Mar 7, 2005 | 10:19 PM
BigBlue's Avatar
BigBlue
Best way I've found is to roll into the throttle. Don't just mat it or you will spin. Just easily, but aggressively roll into it and you shouldn't have a problem.
Old Mar 7, 2005 | 10:23 PM
fast 98 C5's Avatar
fast 98 C5
Let them get good and ahead and run them down !
Old Mar 7, 2005 | 10:24 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Rolling on the gas is a good way to maintain traction... never stab the throttle under 100 mph...
VR
Old Mar 7, 2005 | 11:21 PM
JYC5's Avatar
JYC5
What tires are you running and how wore down are they? I noticed with my old runflats and not much tread left, car was really squirrelly. New tires hook way better. I can slip the clutch to get going, nail it and get a little wheel spin but care is moving out fast. Cold weather affects traction too
Old Mar 8, 2005 | 01:15 AM
90 droptop's Avatar
90 droptop
BFG KD on the street and E.T. streets at the track. Oh yeah, knowing when and how to hammer it helps.
Old Mar 8, 2005 | 06:38 AM
Mitch C's Avatar
Mitch C
Old Mar 8, 2005 | 06:46 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
Coming from someone with these numbers in thier sig - it is safe to follow that advice!
Speed Demon 434
10.65 @ 128.25 Best to date N/A
1.47 60' 6.8 1/8 @ 103MPH
2003 fastest street vette in Texas NA Winner
2004 N/A LS1 tech shootout
http://www.speeddemonmotorsports.com
Old Mar 8, 2005 | 08:53 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
345/35/18s or 345/30/18s
Me roll into the throttle....................
Old Mar 8, 2005 | 02:37 PM
Mike Mercury's Avatar
Mike Mercury
sticky non-EMT tires, throttle management, clutch management (for the manual tranny folk).
Old Mar 8, 2005 | 02:40 PM
BigBlue's Avatar
BigBlue
Now that's a tire.
Old Mar 8, 2005 | 02:51 PM
EHS's Avatar
EHS
C5 comes standard with a traction control pedal.
It's found all the way to the right in the driver's footwell.
Old Mar 9, 2005 | 03:46 AM
EVILNESS's Avatar
EVILNESS
What kinda tires are those? and what size and need me some of them my 335/30/18 Michelin Pilots are not cutting it.
Old Mar 9, 2005 | 07:50 AM
Cruise-In V Veteran
NCM Ambassador
These are off a Jaguar XJ220 (140 tread wear) and net me 1.75 at the strip. Work great on road courses, autoxing and long trips. My car is tubbed to fit 18 x 12 wheels on the back.
The drag radials are bfgs, ok on the street as long as its dry and you don't mind how it pickes everything up with its soft compound.
Nitto also makes a good all around tire.
If you are below 400 at the wheels you don't need that big a tire at the strip.
Our 00' vert is near 350 RWTQ and sticks with 275/35/18 drs to a 1.72 60'. Anything with treads will be tough to get to stick consistantly........just takes time & pressure playing
Old Mar 9, 2005 | 10:30 AM
Mike Mercury
WOW !! that looks seriously bad-azzed
Old Mar 9, 2005 | 10:48 AM
simpleman68's Avatar
simpleman68
Old Mar 9, 2005 | 10:49 AM
Z06-JIM's Avatar
Z06-JIM
It's really hard to resist laying down some serious rubber on the pavement anytime I'm driving it.
I try to save most of those urges for the track with the drag radials.
To Traction...how do you guys..
