Z-51 Front Spring
Old Mar 10, 2005 | 11:19 AM
Bogwon's Avatar
Bogwon
Default Z-51 Front Spring
The dealer is replacing the front spring in my 2001 Vert. I have the Z-51 option. Is the front spring different with this option? I've heard it is the Z06 spring. I want to make sure they order the correct part. thanks
Old Mar 10, 2005 | 11:45 AM
yellow01's Avatar
yellow01
If by different you mean from the base yes.
From ls1howto
The GM part numbers for the different suspension springs are:
- Z06 Front spring: 22178729
- Z06 Rear spring: 22188038
- Z51 Front spring: 22178729 (note: same as Z06)
- Z51 Rear spring: 22179020
- Base Front Spring: 22178728
- Base Rear Spring: 22179019
Hope this helps!
Old Mar 10, 2005 | 12:54 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
From ls1howto
Hope this helps!
Old Mar 10, 2005 | 05:11 PM
Bogwon's Avatar
Bogwon
Thank you.
Old Mar 11, 2005 | 01:49 AM
FiberglassFan's Avatar
FiberglassFan
Does anyone have the data on Lbs per inch deflection for each of the springs?
Old Mar 11, 2005 | 08:33 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Yes, Hereyou go!
439.66 lb/in, front; 576.70 lb/in, rear (manual trans); 588.12 lb/in, rear (auto trans) --- FE-1/Base --- Source
440 lb/in, front; 577 lb/in, rear --- FE-1/Base --- Source
457 lb/in, front; 577 lb/in, rear --- MSRC --- Source
525 lb/in, front --- FE-3/Z51 --- Source
660 lb/in, front --- FE-3/Z51 --- Source
327 lb/in, rear --- FE-3/Z51 --- Source
633 lb/in, rear --- FE-3/Z51 --- Source
634 lb/in, rear --- FE-3/Z51 --- Source
525.31 lb/in, front; 633.80 lb/in, rear (manual trans); 645.22 lb/in, rear (auto trans) --- FE-3/Z51 --- Source
525 lb/in, front; 634 lb/in, rear --- FE-3/Z51 --- Source
620 lb/in, rear --- FE-4/Z06 --- Source
650 lb/in, front; 680 lb/in, rear --- FE-4/Z06 --- Source
525 lb/in, front; 714 lb/in, rear --- FE-4/Z06 --- Source
650 lb/in, front; 800 lb/in, rear --- T1 --- Source
VR
Old Mar 12, 2005 | 12:11 AM
FiberglassFan
Thanks! Exactly what I was looking for!
I'll be copying this into my permanent data book!
Jennifer
To Z-51 Front Spring
